Typhoon Daysailer Mast Stepping
Re: Typhoon Daysailer Mast Stepping
Okay, I need some help.I'm totally at sea (pun?) with this talk about cutting a slot or notch in the cuddy roof behind the mast.
I'm trying to visualize the purpose of the slot. What are the dimensions of the cut? How does it aid stepping or unstepping the mast?
A picture or two would help my inquiring mind a lot.
"If I rest, I rust"
Voting Member #490
Voting Member #490
- mashenden
- Location: "Nautica" CD-36 #84, Ty-K #83, & CD-10 #1539 in Urbanna, VA. 4 other Tys in past
I envision it as being a way to raise the mast by letting the end rest on the cockpit floor making it easier to pivot into place. Without the notch, one has to also lift the mast another 2 feet vertically and drop it into the hole (which requires a gin pole, cherry picker, or Popeye sized forearmsOswego John wrote:Okay, I need some help.I'm totally at sea (pun?) with this talk about cutting a slot or notch in the cuddy roof behind the mast.
BTW we are talking Daysailers here, not the Weekender.
Matt Ashenden
- I used to like boating and fixing stuff, then I bought a couple of boats and now I just fix stuff![Smile :)](./images/smilies/icon_smile.gif)
Hi Matt,
From what I gather, they are talking about the Ty Daysailer, type "K". I believe that it has an open cockpit with a small open cuddy cabin for storage.
"If I rest, I rust"
Voting Member #490
Voting Member #490
- mashenden
That's exactly right, John:)Oswego John wrote:Hi Matt,
Matt Ashenden
Thanks Matt-
It is a 1979 cuddy Daysailer. I confused the hull number with my 1981 Sabre 30 which is hull#79.
I'm not at home right now and will have to get back to you with the Hull number for the Ty.
Regards-
Roger
Regards-
Roger
Matt-My TY Daysailor is Hull #22.
Sorry about the error.
Regards-
Roger
Regards-
Roger
- mashenden
LOL. Now that you mention it, I now see that Magic Carpet was already on the list. Silly me:)
Keith Wood - Any information that you can provide on Daysailer hull #88 would be appreciated, particularly the year since we have a notable gap in Hull # data between #69 (1981) and #107 (1983). I'd like to add yours to the list.
http://www.capedory.org/board/viewtopic.php?f=1&t=30007
Matt Ashenden
