barfwinkle wrote:This is a family friendly site Robert. You mean Bass Ackwards
fair winds
Very well.
Sooooooooo, I have apparently done things "Bass Ackwards".
In no particular order of stupidity, I document the following:
1. I assumed I had to remove the "seacock" before removing the "thru hull". According to Paul at Spartan Marine - wrong
Remove the "thru hull", then remove the two nuts, washers, bolts, etc. and then remove the "seacock".
2. I assumed the "seacock" included the "thru hull". Wrong again.
They are two separate parts that are sold separately. Having ordered a "seacock" several days ago, today I asked Paul to send me a new thru hull. Surprise
Spartan is out of this size thru hull but hopes to be able to ship in two (2) weeks, possibly longer. So, S/V Bali Ha'i will remain on the hard for several more weeks at least. Working on sailboats is FUN
3. I removed one of the two bolts holding the backing plate and flange base of the seacock body in place on the interior of the hull. The bolt appears to be bronze. In attempting to remove the other bolt I managed to sheer the bolt into two pieces. As of now, neither piece will come out.
4. I am trying to find a place that sells bronze bolts, washers, nuts, etc. so that I do NOT use dissimilar metals on the seacock and thru hull. So far no luck. Will try "McMaster Carr" (sp
) later today.
5. Still unable to find a "step wrench".
Chris, I tried all of the local Home Depot stores. None of them carry the item you referenced. Paul (Spartan Marine) suggested using an auto parts store to see if they have a "radiator step wrench". Paul said it may work but may not be strong/solid enough to overcome the forces that are holding the thru hull in place.
A brief comment about Paul at Spartan Marine. He spent almost 1/2 hour with me this morning explaining in "painful" detail the correct steps for removing the seacock and thru hull and offered suggestions about tools to use instead of a "step wrench". (1/4" flat bar steel, Stilson wrench, etc.) Paul was very helpful and he did not laugh once at my many, many mistakes. Good guy.
When this "seacock/thru hull" project is done I will be an "expert" at thru hull removal and installation, perhaps almost as good as Maine Sail.
Says the dummy in jest.
So, if anyone has any pearls of wisdom, suggestions, recommendations, etc., I will be very grateful.
