Michael Heintz wrote:First Maine Sail,
Fascinating test......and interesting results. I have a 35 lbs original CQR, with over 50 ‘ chain and never had a problem ( CD 30 MK II ), sailing in Long Island and Cape Cod. Originally had a 25 lbs Danforth, I now use that as my second anchor.
I must sat I am unfamiliar with the Rocna, but am VERY impressed with your test results !!!!
Anyone else have an opinion on the Rocna?
Maine sail thank you for that video test......extremely informative and done with great effort.....
Let’s continue the dialog.....there is nothing better than this board and the information gained from it!!!!!!
Michael,
I am one of those guys who likes to see how things work. As a result I have played around with all my anchors on intertidal areas on both hard and soft surfaces and one day I brought my video camera.
I now own a digital load cell and when I get some time over the off season plan to see what they hold in a similar substrate. Believe it or not the CQR has been one of the worst performing and not jsut in hard substrates. I used CQR's for many years and was never comfortable after my intertidal testing I now know why. In many instances, even once set, I could drag a "properly sized", by manufacturers spec, CQR with only the reverse thrust of my engine and that should NOT happen. Don't get me wrong I have hundreds of successful anchorings with CQR's but many of those took two or three tries to get a good solid set. I don't have much tolerance for multiple sets and re-sets because I do all the anchoring myself and rarely use my windlass. The new gen anchors set almost instantly, like you're tied to a cement jetty...
While I don't believe the perfect anchor has been built yet the Manson Supreme and Rocan are the best I've experienced in various bottoms from hard to very soft silt. For old gen anchors I still like the Bruce if you up-size it. I have used many anchors over the years and still own 2 Spades, 2 CQR's, 1 Bruce (now on loan to Dean
), Supermax, Fortress, Rocna & Manson Supreme. I sold my Delta with the last boat which is also not a bad anchor in terms of "old technology" but I still prefer a Bruce over the Delta and a Spade, Manson Supreme or Rocna over any of the "old gen" anchors....
While many people only anchor when they have to I have spent a great deal of time experimenting and putting mine through the paces to really see what they can do when pushed hard and to the limits. I actually put myself in a Nor' Easter out in front of the house with my Rocna to see what she'd do but peak wind speed only hit 52 so it was not the storm I thought it was and not really a good test..
