The clear fuel is for road use, is taxed, and has chemicals in it to provide sufficient cetane for road use. It assumes that the engine is relatively new, and is designed with harder valve seats to stand the impact of combustion without Sulphur, which this fuel has been scrubbed of.
The non taxed, red dyed fuel is for off road use, also marine use. The fuel has higher sulfur content which meets the engine requirements of your diesel better than the taxed fuel. It softens the impact of your engines' valves with the valve seat for one thing, and unless the engine is relatively new, this is actually needed to help it run smoothly and well.
Protect your engine investment, as it is the highest priced item on your boat. Currently, a used Volvo MD7B is being installed for around $10k, according to my marina owner who has around 120 rebuilt engines in his machine shop, and sells them to the marinas doing the replacements.
A new replacement would be another 4-5k on top of that. This is for an old 13hp motor!
Good Sailing,
Larry DeMers
s/v DeLaMer
Cape Dory 30 sailing Lake Superior
cguthrie wrote:I'm thinking about relocating my mooring to a place that doesn't have a fuel dock and I'm wondering about the logistics of keeping the tank filled. We have a Yanmar 8 diesel.
1. I read that the only difference between auto diesel and marine diesel are taxes and dye. Is that right? -- so if I don't mind paying a little extra to avoid having to motor to a port with a fuel dock I shouldn't have a problem?
2. I'm wondering about the safety of keeping an emergency fuel supply in a secondary plastic can aboard. Do other folks do that as a matter of course? In general I try to keep explosive things to a minimum on the boat.
