Hello Wingreen:
I share your dismay. I had an unfortunate personal matter that has taken a lot of my time.
As you may recall, I moved S/V Tadpole to her mooring on Monday, 07 April with high hopes of sailing her on Wednesday and Thursday of that week.
As luck would have it during the evening of Tuesday, 08 April and early Wednesday morning, 09 April, the hot water heater
inside my house (bad architectural design) broke (main heating element pipe snapped in two) and flooded my house with almost 400 gallons of water. Restoration company truck has a 127 gallon tank. They filled it full more than 3x
When I stepped out of my bed Wednesday morning, 09 April, I stepped into 2" of water. All rooms completely flooded. Carpeting, floor boards, etc. all soaked.
From 09 April through Tuesday, 22 April, I had to be at home every day for the "restoration co" to take daily moisture readings of the drywall, etc. to position and reposition fans, blowers, heaters, dehumidifiers, etc. (a total of 24-26 units in the house). Sounded like a jet engine. I was also trying to salvage what I could that was not destroyed by water damage. I lost a lot of significant memorabilia, photos, etc.
All equipment was finally removed on 22 April. I am told drywall is dry and little chance of mold forming.
I had planned on two separate days last week to practice dropping and picking up a mooring ball single handed and then going out into Biscayne Bay to raise sails. Unfortunately, both days had winds significantly higher than I would be comfortable with at this point single handed. I was also still "on probation" at the sailing club and did not want to accidentally play "bumper boats" with any expensive and large sailboats.
On Friday, 25 April, I was surprisingly accepted into full membership at the sailing club and learned the secret handshake, etc.
I was going to go sailing today. Unfortunately, high winds (14-17 kts). Hopefully, in 3-4 months 14-17 kt winds will be what I am hoping for
Not just yet.
Tomorrow is forecast to be fairly calm on Biscayne Bay according to
www.sailflow.com so I hope to be on board S/V Tadpole tomorrow afternoon. The morning must be spent with A/C service tech fixing one of the A/C units. As you may recall, the "Admiral" has departed so all duties fall to . . .
IF I get out tomorrow, I will certainly report back to my "support group" on my efforts and results.
I plan on also practising removing the pigtail while head to wind and just before raising the mainsail. That seems to be the consensus best course of action until such time as I can install a proper topping lift.
Wingreen, I appreciate your concern and your support and encouragement. I am very anxious to raise sails on S/V Tadpole. I just want to try to do so judiciously, at least for the first 3-4 months until I get to know her.
