Jessica wrote:Rick,Rick Parish wrote: Jessica - Sounds like we should take your deck and my hull and make one new boat. Your hull problems sound serious, but I would suggest you get a second opinion on the condition of the fiberglass. I'm no expert, but ..... Is fiberglass less expensive than epoxy? I haven't priced fiberglass. It sounds like you are planning to put a new layer or two of laminate over the existing fiberglass. Correct? Have you read anything about how to do that? Advice from friends?
The delamination I referred to in my boat is on the deck, not the hull as you indicated. There is a core in the deck. I've almost completed sanding and fairing the decks in preparation for primer. The delamination is about 4 sq. ft on the aft deck and it's taken over 2 qts of epoxy to fill the void left by the rotted core. Thank you for the idea on how to find voids in the hull/deck joint. It worked. I appreciate your comments about mahogany vs teak. The trim around the companionway is mahogany, so is the bulkhead. The coamings are also mahogany. Sliding hatch and cockpit seats are teak as is toe rail. Diversity. Do you know anything about how to fix a crack in veneer? Looking to the future, I'm going to need some brass deck fittings - cleats, jib track, chocks, traveler. Any ideas on where to look? Most of the retail outlets in Tampa offer only "the new stuff". Older style brass hardware has not exactly jumped off the shelf into my shopping basket. Thanks for your help, back to the sander tomorrow. Rick
We have the Spartan catalog and can get the address if you like (I don't have it on me)--they have good stuff, for a price. Do you have a motor mount? We spent a lot of time combing some "used marine goods" stores, there are a couple here in New England. Thing is, most of the items are not any less expensive, even though they are used. I know there is a place down in Florida like that, as a friend has told me, I can also find out details (sorry, not being very specific today).
Yes, I do know about fixing veneer, if you have not solved that yet. First, assess the problem: Is the crack just in the veneer? Can you still use the veneer, or is enough lost or warped so that you will need to replace it? Sometimes it is easiest to just fill the void with filler, varnish the sucker, and live with it. You can disguise discoloration with a brown marker. If the crack does not lie flat and the veneer is still in good shape, you can pry up the edges (carefully!), squoosh wood glue in, and clamp the piece between two flat boards--use wax paper! though when clamping, so as not to glue your piece to something it shouldn't be lued to. If you need to remove the veneer--if it is warped, or some of it is missing, take a razor blade and cut out the crack and the veneer in a diamond shape if the crack does not extend to the edge of the backing, a wedge shape if it reaches one edge (the point where the crack starts and getting wider towards the edge on either side of the crack) and a strip if it extends through the whole piece. Take a piece of veneer, or the whole panel if you can, to the wood store(a hardwood store should have veneer, but also furniture makers etc) and find a matching piece. Remember that varnishing or finishing will darken it, also you can cheat and stain it or whatever--don't worry too much, as the wood will also darken naturally and blend in over time. Cut the new veneer to match the pattern you cut out, smear both glueside pieces with glue leaving NO ungluey wood, clamp between two flat boards and leave for a day or two. It's best to clamp, and apply good even pressure, but also just putting cinderblocks or something on top will do. If youwant to invest some money in glue, get soemthing called "Gorilla Glue", as it holds up much better in marine environments. Remember the wax paper!, and scrape off excess glue& paper with razor, sand and finish.
Fiberglass resin is much less expensive than epoxy or vinylester, but also less water resistant. We are not sure what to do--is it worth investing the $$? As the fiberglass guy said, well you can put diamonds in the side of the hull, sure, it'll be stronger, but is it worth it?
parish6@ibm.net
