My boat has a slight list to starboard ... when I mentioned this to my son when we did lots of restoration work a few years ago, he said "Dad, how fair do you think the molds were for these old boats ? " ...
nhammatt wrote:The deal with your waterline? - it isn’t straight, from the factory. It’s almost as if they followed the line parallel to the sheer.
I had mine corrected with a laser level, it was nearly 2” high at the bow.
Every 22 I’ve ever seen has the same swoop at the bow.
Next time I’m near the boat, I’ll measure down from the stem fitting and post it for comparison.
Nice winter project ahead for you!
Assuming the cabin sole and cabinetry surfaces are both level with the designed waterline, I'm seeing about 0.5 degree bow-up trim. Assuming the center of buoyancy is half way along the waterline (probably not correct, but it simplifies calculations), that equates to about 7/8" at each end of the waterline. Looking at the photos, the boat seems to be up about 3 inches at the bow and has zero bottom paint showing aft.tartansailor wrote:Squat is S-L-O-W!
Now on my CD 25 The cabin floor is parallel with the bottom of it's keel.
Put a level on your cabin floor and see what you get.
I'd guess that adding useless dead weight in the ends is not going to improve performance. Are you primarily concerned with appearance even at the expense of performance?wikakaru wrote: ... Maybe as a temporary fix I should try adding a lead pig (or, as someone suggested, a dead battery) up forward , and repair the waterline and boot stripe later ...
Sounds like I need The Admiral to sit forward through a few tacks and see what moving weight forward does to the boat's handling.Steve Laume wrote: Having a rise in the waterline or boot stripe at the bow is an intentional feature. It is more difficult to do than a straight boot stripe and is quite pretty. There is certainly no reason to eliminate it unless you find it unpleasing for some reason.
Stern squat does slow down a boat. Adding excessive amounts of weight in the bow to counteract it also slows a boat down. Being low in the bow makes a boat squirrely and harder to handle. Keeping the boat balanced without excessive weight in the ends is what we should strive for, Steve.
Thanks for sharing the photo of your waterline! It looks like you have the same bow "smile" as I do, with the paint curving up as it gets to the bow. Cape Dory must have had some kind of template that they used to paint the waterline in that shape.NarragansettSailor wrote:Here's my CD22D at mooring for comparison - bow seems slightly elevated but there is no water in the tank under the v-berth. The Yanmar 1 GM (6.5 HP, approx. 65 lbs) is located under the bridge deck so it is better centered than lazarette- or stern-mounted outboards.
Please excuse the head of the mainsail poking out from the mainsail cover - we had 50 kt winds the night before. So glad I went oversize on the mooring anchor - one does sleep better at night
