The more research I do on this the more I am coming around to the idea suggested by John S.
Unfortunately, I am not the sharpest knife in the drawer so I have some concerns/questions, etc., about installing the Hella Water Resistant Chrome Brass Plug & Socket suggested by John.
Am I correct in understanding that the wiring from the charger controller would be connected to the Hella's socket portion and then the wiring from the solar panel would be connected to the Hell's plug. When the plug is connected to the socket "we got juice"
As with most holes drilled in a boat, I am assuming that I would drill a 1" or larger hole in the cabin roof (or wherever I plan to install the plug and socket) and then clear out the balsa core around the hole and then fill it all with epoxy to prevent water intrusion. Then drill a small hole just large enough for the wiring to come up from the charge controller, thru the coach roof and then to the socket. Does this sound about right
At this early planning stage I am thinking of installing the Hella Water Resistant Chrome Brass Plug & Socket on the port side near the aft end of the coach roof. On the Cape Dory 25Ds there is a handrail there that I can use to tie off the solar panel to keep it from flying away in windy conditions while on her mooring or at anchor. This would also minimize the wire run from the batteries to the charge controller to the solar panel since the batteries (2) are located on a platform inside the port side cockpit locker.
For those that have a Cape Dory 25D, 27 or 28 (I think the coach roofs, etc. are similar in design and configuration) is this a reasonable location for the Hella Water Resistant Chrome Brass Plug & Socket and solar panel or have you found a better
Thanks to ALL for the many suggestions, recommendations, advise, encouragement, etc. It is much appreciated.
I wish to have no Connection with any Ship that does not Sail fast for I intend to go in harm's way." Captain John Paul Jones, 16 November 1778, as quoted in Naval History and Heritage Command,
http://www.history.navy.mil
