Notjr818 wrote:Lisa G,
Are you posting a message along with the quotes? All I see are the quotes themselves, I don't see any message.
Is anyone else seeing a message?
Block for flag hoist on mast spreader
Re: Block for flag hoist on mast spreader
Capt Hook
s/v Kumbaya
Cape Dory 31, Hull No. 73
New Orleans, LA
s/v Kumbaya
New Orleans, LA
I use two small harken bullet blocks for my flag halyards. The one in the photo is $14 at WM. I think I bought them at Jamestown Distributors for $9. You can also use a small schafer micro block as well. My spreader is a little different than the stock rig rite spreaders. I bet you can drill and tap a small pad eye onto the underside of the spreader. Typically you locate the pad eye about 1/4 - 1/3 inboard of the tip of the spreader. Don't forget to lube the threads of the fasteners with some anti galvanic paste. I use tef-gel.
One block would work fine. By using two I can hoist my radar reflector and it won't chafe on the halyard. I fly the Q flag and host nation flags on the starboard spreader and the radar reflector on the port spreader flag halyard. I use 3/16" - 1/4" double braid Dacron line for the halyards.
John
John
John S.:
Thank you. I will stop at WM and check out the Harken blocks.
