Roberto,
You deal with an electric motor every time you start your diesel unless that is you crank it by hand. So I have to ask why doesn't not seeing those electrons bother you? Then add on top of it many more systems; lubrication, fuel, air, water, impeller, electric fuel pump, fuel line, water hoses, through hulls, fuel filters, air filters, water strainers, muffler, anti siphon. Not to mention dozens of moving parts in the iron beast. Now think about the one moving part of an electric motor, the rotor!. Then think about how do you make diesel fuel in the middle of the ocean for those blue water cruisers. Roberto I'm not poking fun at you, I'm poking fun at all of us because we all feel this way. As Spock would say it is highly illogical. We humans are creatures of habit and highly resist change.
Maine Sails,
As always you have added great insight and information to help us navigate through these turbulent waters of electrical propulsion. Thank You
Steve & tjr,
I have been pondering the resale question as well and unfortunately I think Steve is correct that it would be more negative then positive for the reason I pointed out in my reply to Roberto, sorry Roberto I didn't mean to be so hard on you.
jepomer,
Glad to see you using electric power and that it is working well for you but unfortunately it is really a different circumstance with the outboard vs the inboard. Meaning that the complexity to switch back to the internal combustion engine is quite a bit simpler for an outboard
I will continue to monitor Electric propulsion and maybe by the time my beloved MD7A gives up the ghost the battery technology will have progressed to the point that this becomes a no brainer. You could argue that it is already pretty close to a no brainer. The problem is that we let emotion in this case comfort of the known verses the unknown over rule the logic of using a system that significantly more efficient and at least an order of magnitude less complicated.
Thanks for all of your comments and I'll keep you updated as I discover more.
Keith
