Extending anchor chain
Re: Extending anchor chain
Sea Hunt Video wrote:
Jim Walsh wrote:You could always clean the rusty section and spray it with cold galvanizing compound (paint).
Jim and all:
What do you recommend as a cleaning solvent for rusty chain :?: I recently was given about 20' of chain in good condition. It does have some surface rust on 50% of the links but the links appear to be solid. I would like to clean off the rust and then spray with Rustoleum's cold galvanizing spray.
Thanks.
I've read that a common method of removing surface rust in Mexico is to tow the chain behind your jeep for a short time while driving through the sand dunes or on a beach. Maybe the Chevy pickup can be employed to solve your rust removal problem.
The Brits soak theirs in various caustic brick cleaning chemicals. I'd be wary of that method myself.
Sea Hunt Video
Post by Sea Hunt Video »
Thanks for all the interesting posts. Entertaining. :)
I think I will go with one of Tim's suggestions - Naval Jelly.
http://www.homedepot.com/p/Loctite-16-f ... /203009241
Can't go too far wrong for $7. Although the website says it can be "sprayed on" it cannot. It can only be applied with a brush.
Thanks Tim for the recommendation/suggestion.
