As an experiment tie a block to the rail and try it. Use a clove hitch on the rail and run the tail down to the quarter cleat real tight. If it does what I think it will do make it permanent and run a reinforcement down to the deck so you don’t lift/shift the rail. Split sheets are the way to go on a mizzen.
For experimentation almost any line will work and you don't need more than one block. If you like it then you will want to get a bit more fancy and probably go with a three part tackle with cam cleats similar to what is used for boom vangs.
How to know when you are heeling 15 degrees?
Re: How to know when you are heeling 15 degrees?
I am going to give it a shot this weekend, if I get my autopilot working. I had to send the control head back to Raymarine and it required a software upgrade. Tested it in the garage and fired right up.
I prefer figuring out new sail mechanics any day to software gremlins...on my sailboat. BUT, being able to single hand my boat with two little girls aboard is a big plus.
Kind Regards,
Adam
Adam
