I am hopeful that I am not "tacking" this thread away from its initial post. If so, I apologize to Jack Carr.
On my new-to-me 1982 Cape Dory 25D (Yanmar 1GM) the prior owner removed the thermostat when it began to malfunction and did not replace it. The CD 25D was homeported in NJ at the time.
During an engine survey sea trial in NJ, the engine overheated when run at about 3,400 rpms.
I am wondering if I should install a new thermostat
I do not know much about diesel engines but assume a thermostat works about the same on a diesel as a gas engine. It opens to allow more water (or coolant) into the engine once the engine gets to its normal operating temp and allows the engine to maintain a certain temp range. Simplified I know.
Given the generally warm South Florida waters (85 degrees summer; 75 degrees winter) is there really any need for a thermostat on a 1982 Yanmar 1GM
I have no problem purchasing and installing one but wonder if there is any need/benefit to doing so.
Suggestions, recommendations, advise are much appreciated by this "rookie/tadpole" sailor.
I wish to have no Connection with any Ship that does not Sail fast for I intend to go in harm's way." Captain John Paul Jones, 16 November 1778, as quoted in Naval History and Heritage Command,
http://www.history.navy.mil
