Joe Myerson wrote:
--Power-washing: Is this something I can do myself, renting a power-washer for a day?
Yes of course you can, but, it is very dependent upon your boat yard and where you plan to wash it down. If you washed it in your yard at home, and the boat was over grass, no grass would grow there for many, many years due to copper content.
Our boat yard has ONE spot for washing boats and a 300k catch basin with filters etc. to catch and filter the run off. Don't worry within a few years EVERY boat yard will have these. That location is at the travel lift. If you try to wash your own bottom on the hard anywhere other than at the catch basin the owner will likely boot you from the yard for violating EPA rules, and now yard policy, which was driven by the EPA. In short the EPA has made it impossible for any DIY to wash their bottom at our yard here in Maine. The yard has a 300k investment to recoup and they rightfully will not allow a DIY to bring in their own pressure washer.
Joe Myerson wrote:--Winter cover: I'm sure I can find somebody to shrinkwrap the boat, but don't know if they'll be any cheaper than the yard. I don't have much faith in tarps, but cannot afford a Fairclough cover this year -- even though I spoke with them, and they're eager to offer deals.
A Fairclough will save money over the long haul but NOT the short haul. You can easily erect a frame and used a heavy duty green tarp, Hamilton's has them, provided you don't have an Awlgrip or painted finish, for well under $100.00.
Joe Myerson wrote:
--Engine winterizing/maintenance: Even though the IGM is about as simple an engine as there is, I'm kind of a mechanical klutz. Can I attempt this myself, or should I contract it out. Oh, the water pump needs replacement. That looks like an easy job, but should I attempt that, or lump both jobs together and hire somebody?
This is a DIY job but you really need to remove the t-stat in order to properly flush the cooling jackets on the RWC 1GM. I always install a brand new t-stat on a RWC engine when I do this as they sit in salt water all season and not pampered in rust inhibiting antifreeze..
Never connect a pressurized hose to a raw water intake and ALWAYS use an in/out bucket. Garden hose feeds the bucket and a hose from the raw water pump sucks out of the bucket.
Change the oil, run fresh water through the engine then run non-toxic -60F or -100F antifreeze through it. DO NOT use the pink kind for the fresh water systems as it contains NO rust inhibitors when compared to the -60F or -100F stuff intended for engines. Also keep in mind that this stuff is NOT intended to be dilute in ANY FORM OR FASHION. For this reason alon you will want to suck 3-5 gallons through to make sure your burst points are low enough.
Remove the impeller after sucking in the antifreeze. Any of the propylene glycols (PG) can shorten the life of the impeller rubber whether it is pink, purple or deep green prop glycol. Remember this glycol is still in the alcohol family and can shorten the performance life of rubber. Usually the engine rated stuff (-60 & -100) have better corrosion packages in them and it is especially important to use them in a RWC engine to prevent slab rust from forming.
Basically none of the PG products should be diluted. The -50, -60 & -100 are all general guides for undiluted burst points NOT set in stone and standardized tested freeze or burst points.
-50 for example contains only about 30% by volume, propylene glycol. Reducing that concentration, through dilution, the water already in the raw water loop, to just 12.5 percent PG by volume, raises the BURST POINT to about 20 F which is a far cry for -50 @ 30% PG by volume. Run enough through it is CHEAP insurance!!!
It is a good idea to drain the raw water side first or just use more antifreeze so you know it is not diluted. My raw water side can hold nearly two gallons of raw water between the strainer, hoses, HX, water-lift muffler and my refrigeration heat exchanger. This could mean major dilution, and in Maine, that is NOT a good idea.. This is why I drain it first before sucking in the -100 PG. I only use the -100F PG for my engine.
If you read the label on -60 for example it says copper pipes may burst at -60F but that plastic is only protected to -26F and this is UNDILUTED.
Joe Myerson wrote:--Draining systems and adding antifreeze: These jobs seem simple enough, but I'd hate to mess up. I have a very basic freshwater system and a head that seems to have a clogged vent. Any suggestions?
Please do yourself a favor and by-pass the water heater. Also, DO NOT add pink PG directly to the water tanks. It is unnecessary and very difficult to bleed through via dilution in the spring. Simply drain the tanks then suck antifreeze ONLY through the pipes, fixtures and H2) pump/pumps.
Here's a primer on fresh water system winterizing:
http://www.pbase.com/mainecruising/wate ... interizing
Joe Myerson wrote:--Battery storage/maintenance: I have two lead/acid batteries. They're heavy, but I could probably charge them and store them in a heated basement. (There's a thread on this subject, I know.)
No need to remove them from the vessel. Cold batteries have a significantly SLOWER self discharge rate than warm batteries. A fully charged battery WILL NOT freeze where you are. Charge in the fall to 100% then DISCONNECT them and leave them on-board. When you visit the boat in the winter apply the charge for an hour or so every now and then and they will be more than fine come spring. Only a dead battery will freeze.
Joe Myerson wrote:--Electrical problems: During the trip to and from Bristol, RI, I discovered that my VHF antenna circuit has a break someplace, and some of my lights don't seem to work properly (no steaming light or deck light).
Get: Boatowner's Illustrated Electrical Handbook Second Edition by Charlie Wing
I find it to be the best book for a beginner and it follows ABYC standards, which is what insurance companies are looking for. Nigel's book is also great but is often over the heads of most 12/24V DC neophytes. Your problems are all most likely bad connections which are easy to fix.
Here's how to re-terminate a VHF cable:
http://www.pbase.com/mainecruising/vhf_cable
Joe Myerson wrote:--Bilge: The yard always puts some of that RV antifreeze in the bottom of the bilge to handle any potential freezing.
Ideally I prefer a garboard drain on a deep full keel boat. If you are concerned about FW getting into the keel sump then PG won't actually do much as DILUTION significantly increases the burst point. I have seen LOTS of boats with bilges frozen solid with pink stuff in there. I have also seen full keel boats split the keel from freezing.
Joe Myerson wrote:--Have I forgotten anything important?
--Joe
Drain the fuel tank and burn the oil in your home furnace or a friends. Remove the cushions, sails, cotton sheets etc. etc and TRY to keep your bilge as dry as possible. This will help prevent interior condensation which can ruin wood work. I have been on boats that were making SNOW inside them in their own little eco system due to a wet bilge.
