CD 36 mainsail traveller controls options
David L
Post by David L »
Here's the setup on Raven. Can't claim any credit; the boat came this way from PO. Traveler is the original Nicro system.
Troy Scott
Should I buy the traveller?
Post by Troy Scott »
Folks, My traveller looks like the photo of the one on Raven, except that his sheaves appear to be aluminum. Mine are (sigh) plastic. Was this system standard, with the blocks for pulling the mainsheet to port or starboard? Or was this an upgrade? Considering that I have this, would it be worth one or two boat units to do the upgrade like John Danicic and others have done?
Of course there is still the issue of the plastic sheaves. I've had many of these shatter unexpectedly, including four at once during an accidental jybe (another story).
IF (big if) I keep (after improving) the system I have, where would I find replacement sheaves? And what magic is required to install them?
I'm secretly lusting after John's setup, but like most of us these days, I'm of a budget. Isn't "budget" a four-letter word? Maybe I've misspelled it.....
Regards,
Troy Scott
John Danicic
Post by John Danicic »
Troy:
I am still working on my set up. I got the towers and traveller mounted the last time I was up but still need to install the direction reversing down blocks and clutches. I thought I would do that after I take off the cover and get the dodger on. That should be June 2, which is put in day up in these parts.
It looks pretty good so far though I worry that the travel distance is tighter then the original Nico because the car is much longer and the end blocks take up a few inches on either side. I am confident that the windward sheeting will be fine but a rousing good sail will tell the tale.
As far as cost is concerned, I am under a CD36 boat-unit which, for such a major addition, is not bad.
I will post photos and results after that happy day.
Sail on
John Danicic
CD36 - Mariah- #124
Lake Superior- The Apostle Islands
CDSOA #655
Cape Dory Picture Posts
Troy Scott
Now! Now!
John, you obviously have no idea how excited I am about experiencing (and probably copying) your fully tweaked new traveller setup. Please keep me posted, and send photos! And don't be surprised if I show up at your slip in my sailor suit!
Regards,
Troy Scott
Troy Scott
And another thing
Folks, what about the staysail traveller? I never hear anybody talk about that. Is it just fine "as is" with the manual stops? Or does it benefit from some upgrade that I've not heard about? It certainly would be a long way to run control lines to the cockpit. I don't even do that with reefing lines (well I USED to, but that's just too much clutter.) I've learned, as I approach the ripe old age of 60, to just keep it simple. Thoughts?
Regards,
Troy Scott
bottomscraper
Staysail traveler.
Post by bottomscraper »
Troy Scott wrote:Folks, what about the staysail traveller? I never hear anybody talk about that.
Just did that, pictures coming soon. We used Garhauer again. We
also eliminated the weird "A frame" sheet routing and replaced all
of the stand up blocks. Our boat was just launched yesterday for
the season and our mast was stepped today. We will be busy
with the remains of comissioning and moving the boat to our
mooring over the weekend assuming this peasoup fog lifts.
Rich Abato
Nordic Tug 34 Tanuki
Southern Maine
http://www.sailmahalo.com
Troy Scott
staysail traveller improvement?
Anxiously awaiting pictures! Actually I'm fond of fog. Nutty, I know. It's part of that "alternate universe" idea I was playing with earlier.
Regards,
Troy Scott
jamesbuehner
new garhauer install
Post by jamesbuehner »
just putting this out there FYI; it will be awhile before Diapensia is launched but the lines leading from main and staysail will remain in place as they are unless serious chaffing happens against the turning block below the port traveler wheel....
Jimmy
[img]https://picasaweb.google.com/lh/webUplo ... 8997766449[/img][/img]
“If you think you’re too small to make a difference, try sleeping with a mosquito.â€
bottomscraper
staysail traveller improvement - Pictures
Here are some new pictures showing the new staysail traveller
on Mahalo and her new paint job:
More here:
http://www.sailmahalo.com/picture_colle ... ahalo2011/
Rich Abato
Southern Maine
John Danicic
I like it
Nice job Rich.
Did Garhauer make the stay sail traveller as well? Which model did you get?
Super paint job as well.
Sail on
John Danicic
CD36 - Mariah- #124
CDSOA #655
bottomscraper
Re: I like it
Yes, it is a Garhauer MT-1CT. Most of the raised area of
the deck under the traveller has an aluminum plate encapsulated
in the glass work. When I ordered the new traveller I had the holes
drilled to avoid the original locations since several holes were
already stripped out. New holes were drilled and tapped on the boat for
mounting the new traveller. I also went to 1/4" screws rather
than the original #10's. Garhauer also did the custom bend to
match the curve of the deck.
The stand up blocks and deck organizer are also Garhauer.
http://garhauermarine.com/
Paint, deck repair and non-skid was done by Casey Yacht Enterprises.
Mike Casey and Ed Mitchell were great to work with.
http://www.caseyyacht.com/
Rich Abato
Southern Maine
John Danicic
New CD Traveller installed.
New Garhauer Traveller installed and working. Thanks everyone for all your help and advice. More pictures here. Traveller
It wasn't too bad a job and the rewards were apparent on the first sail of the season last weekend. No more "making due" with the mainsails trim because of a reluctance to adjust the control blocks.
I needed to fashion teak wedge bases for the halyard lift block to fit the curve of the deck. The control lines run nicely under the dodger to the rope clutches in the cockpit
List of items.
Garhauer Items
UR-2 Risers @ 2
MT-UB-2 Mainsheet Traveller with Dodger Conversion. 50" long track.
H25-25SB Halyard Lift Blocks @ 2
11-11S Rope Clutch @ 2
Sail on
John Danicic
CD36 - Mariah- #124
CDSOA #655
