cotter pin length and angle
Oswego John
Cotter Pin Length And Angle
Post by Oswego John »
Good idea, Mark
Might I add that this is one of the rare times that you use solid electrical wire on your boat, not stranded.
Think spring,
"If I rest, I rust"
Voting Member #490
David L
split vs. cotter rings
Post by David L »
If using rings, be sure to avoid using split rings. These are like key rings: both ends lie straight, are hard to open, and a pain to use.
I've used cotter rings for years. They have one end bent inward for easy on-off. They stay put, lie flat, don't snag skin or clothing, don't need tape, and are reusable.
To see the difference, check out:
http://www.jamestowndistributors.com/us ... D&history=
BTW, If my rig came down, I think I'd be reaching for the wire cutters, not turnbuckles.
Best regards to you all,
David
Ron M.
Post by Ron M. »
Right on David. I've also been using the rings for years and much prefer them to cotter pins. Fast to install or remove, with no sharp ends. I bought a box of 100 in various sizes 10 yrs. ago........looks to be a lifetime
supply
________
R100
