I just looked at your website or blog. I am not computer literate so not sure what it is called.
It may well be true that your O/B is clogging up with particles that are in solution in the gas and then, when left for a long period of time they come out of solution and clog the jets. The ethanol in gas (here in the U.S.) helps to dissolve just about everything it comes in contact with - especially plastic and rubber parts. These particles of plastic and rubber then clog the fuel system. The ethanol just makes it worse.
One thing you can do to minimize your problem is to run your engine bone dry after each sail. I am not sure if your 5 hp Suzuki has a small onboard fuel tank and a nozzle/line for an external fuel tank (like my 6 hp Suzuki) or if your O/B has only a line for an external tank. Here in U.S., Suzuki only sells DF 2.5, DF 4 and DF 6. I do not think Suzuki sells a DF 5 in U.S.
Try this procedure. At the end of your sail, if you have and are using your onboard tank, switch the spigot knob to external tank and run the O/B until it burns up the gas in the fuel line, etc. This should take about 4-5 minutes at low RPMs.
If using an external tank, turn the motor off, disconnect the tank fuel line from the O/B, restart the O/B and run the O/B until it burns up the gas in the fuel line, etc. Again, about 4-5 minutes. In this way, you are helping to keep the fuel lines (and carburetor) cleaner, dryer, and not allowing particulate in the fuel to easily come out of solution, dry and clog the jet(s).
This may help a little. If not, it appears you have designed and built an excellent sculling oar for S/V Eleanor.
