Gas station blues
gas station blues
I just can't help but to get my 2 cents worth. You should take a small gas can and pour the first half gallon into it. Then fill the car. You will eventually get enough "hybrid mix" to run the lawn mower. Problem solved. However, does the light in the refrigerator stay on after you close the door? Back in the 50s when I was on a restricted budget we used to go around to all the gas stations at night and lower the hose, pull the trigger and eventually get a couple gallons of ga. Even though the pumps were turned off, there was always enough gas to get home on a limited budget!
