It's definitely noisier than my sailsTell me about that Honda 2hp. I've read that it's noisy. True?
This Fall's issue of Boatworks rated it as an Editor's Choice over 3 other 2 - 2.5 hp 4-stroke motors (Yamaha 2.5, Tohatsu 2, Mercury 2.5) but they tested the motors on dinghies, not on a 1 ton, keeled sailboat. The Honda was the only one available in a long-shaft, but if you move up to a Tohatsu/Mercury 3.5 (both made by Tohatsu, as is the Nissan 3.5), at the same 38# weight as their 2/2.5 hp version (just a different carb) you can get a long-shaft and more oomph. Yamaha has a 4 hp available in a long-shaft, but the weight jumps to 48# (from 38# in the 2.5hp).
The Yamaha 2.5 was the quietest of the 4 tested but the Honda was just a little louder yet quieter than the Tohatsu or Mercury.
My limited experience with the Honda 2 is that it's a reliable 1 or 2 pull starter, cold or warm, and provides decent thrust for most situations, pushing the Typhoon adequately at 1/2 - 3/4 throttle and close to hull speed at full throttle.
