Repairing Teak on CD25
Ben Coombs
King's Point, West Bath, ME
Re: Repairing Teak on CD25
Post by Ben Coombs »
I will admit that starboard is sturdy and long lived... But I felt that it just looked like dirty plastic after it earned a few scratches. I missed the wood color and texture. And doesn't a Cape Dory deserve teak? I'd hate to know what Hervey Garrett Smith would think of starboard! :)
Joking aside, starboard did look a bit funny on a sailboat. Either way, if you're sailing it on a sunny day with good wind, you'll likely not be looking at these rails.
Cheers
Ben Coombs
gates_cliff
Post by gates_cliff »
Agree that a CD deserves teak! And, I do love the look and feel of wood.
Cliff
― André Gide
Jdpmus
Location: Cape Dory 25, hull #169, Zephyr III, Grapevine, TX
Post by Jdpmus »
Instead of trying to glue the cracks, I took mine off and found a hardwood supply in Dallas that had teak in bulk. The owner, Tom, was gracious enough to suggest that I bring the originals to him to use as a template and he would make duplicates. They look like new and fit perfectly.
I'm always impressed by craftsmen (and women) who use their experience and skill to provide a needed service. They are worth their weight in gold IMHO.
gates_cliff
I have a supplier of teak here in Northern VA, Colonial Hardwoods, and they have done a few things for me as well. My problem is I have a stack of teak and need to use it for something! Although, I have to admit, my first inclination is to take the old ones to them, to use as templates, and have them do the milling. I'm sure they'd do a nicer job than I would. If my epoxy fix lasts the summer, I'll have to time to think it over!
Cliff
― André Gide
gates_cliff
Have an additional question on this subject.
Finally decided to try to remove the old teak to take in and have new ones milled. It appears that a previous owner or somebody might have tried the same thing and may have used 5200 to reinstall it. At least that's what it seems. I have a multitool (vibrating saw with an offset blade) that might work.
Anyone have an idea of how to remove without tearing up the fiberglass of the cabin top?
Cliff
― André Gide
I see that most of this thread is a couple of years old. So, my experience may be of limited use to you. Anyway, my companionway slides were also shot. I built new ones from teak but added a UHMW insert that I dadoed for the companion way to slide in more easily. As I recall, the UHMW was about $40. I probably have about $250 in the whole project. I have done some reasonably difficult work, but this project was not one of them. It does require a table saw with a dado stack at a minimum. A planer and jointer are helpful but not absolutely required. I used West Systems Gflex epoxy to glue the UHMW to the teak. Without some basic skills, or a friend who has them and will show you how, you may need to have a professional make them. Here is a link to how I made them. http://www.farreachvoyages.com/projects ... ahood.html
If the PO bedded them in 5200 you can use a piano wire, or guitar string to slice through the 5200 by wrapping the wire around dowell rods and sawing back and forth. You can also use a dremel multi max. I have also used a hack saw blade, remove from the hacksaw bade frame of course. I have had good luck with all three. Be very careful about trying to pull the teak up though. You can tear off part of the laminate.
gates_cliff wrote:Have an additional question on this subject.
Since you do have the Multi-Tool use the offset putty knife blade, It cuts compounds like 5200 very well and does not scratch the fiberglass.
gates_cliff
Thanks I'll give it a try. I plan on being back at home this weekend so should have the time to do some work on my boat. Maybe, just maybe get out for a little sail!!!!!
Cliff
― André Gide
gates_cliff
Another thought occurred to me while I'm slaving away at work! Any suggestions on keeping rain water from getting into the cabin if and when I can get the hatch slides off? It will take some time to get new ones milled and reinstalled and since I'm only back a couple of times a month I could see this being a somewhat lengthy project.
Cliff
― André Gide
M. R. Bober
Post by M. R. Bober »
I have used this on 5200 with very good results>>>> http://www.jamestowndistributors.com/us ... ?pid=63969
Good luck.
Mitchell Bober
Sunny Lancaster, (Where somebody's back is keeping him away from the boatyard.) VA
CDSOA Founding Member
