Core Questions
s-dupuis
Roto Zip
Post by s-dupuis »
I used a RotoZip tool to remove the outer skin on portions of my Typhoons side decks. The tool works like an end mill or a router. Setting the depth to 1/4" allows for careful removal of the outer skin. It's easy to control and you can make curved cuts and radiused corners.
I worked in 10" X 6" rectangular sections and easily peeled off the layer where the balsa was wet. In dry areas the bond was still very good. I left a 1" 'space' of original outer skin between each section to maintain a thickness level reference, but dug out all the wet balsa under the 1" spaces.
I noticed that in places adjacent to where I removed a section and stopped for that weekend, after 5 days exposed to the air, the balsa core was still wet within 1/4" of the edges of the fully exposed section.
Drilling test holes will tell you where the offending areas are but a pattern of holes will not get the moisture out. The refilled holes only act as little fiberglass 'pillars' when refilled, giving the false impression that the deck has integrity.
Troy Scott
deck repair
Post by Troy Scott »
s-dupuis,
After you replaced the wet balsa, how did you replace and/or reattach the original outer laminates?
Regards,
Troy Scott
s-dupuis
Deck repair
Post by s-dupuis »
Troy,
The outer laminate was discarded. I replaced the wood and gradually built up the remaining height with resin, fiberglass roving and cloth. I would then cut out another 10" wide section 1" away from the previous repair leaving a strip of original outer laminate as a height reference (I dug the balsa out from under the laminate). I repeated the process as I went along.
The whole thing was later sanded to an even, consistent surface. My intent was to paint it afterward and add a non-skid surface but I sold the Typhoon for a CD22.
Steve
Troy Scott
balsa deck repair
Steve,
I was curious because I've heard of a repair method in which the original outer (upper) skin was successfully salvaged and scarfed back into the surrounding structure after replacing the wet balsa.
Regards,
Troy Scott
Didereaux
Troy, here is....
Post by Didereaux »
Troy,
Here is a link describing with pictures the whole process you are interested in.
http://www.triton381.com/projects/resto ... ecore.html
There are many more such projects this guy(Tim Lackey) has done on a Pearson Triton that he literally has brought back from Davy's locker.
g'Luk
Didereaux- San Leon, TX
last owner of CD-25 #183 "Spring Gail"
"I do not attempt to make leopards change their spots...after I have skinned them, they are free to grow 'em back or not, as they see fit!" Didereaux 2007
