Self-tailing winches on a Typhoon?
"Second Wind", Cheboygan, MI.
Does anyone have self-tailing winches on their Typhoon, or researched the possibility of installing them?
I do a lot of solo sailing on my Typhoon and would like to free up my hands more, and I think one way would be to have self-tailing winches. I know many of you think the winches on a Typhoon are not really useful in the first place because of the small headsail, but on my 150 genoa, and I am considering adding a 180, I prefer the sheets run to the winches for a better setting of the headsail.
The cost is significant (some $400 + -) and I am just wondering if anyone has experienced the use of such winches on their Typhoon, and would be willing to share that with me. I have used such winches on larger boats and found them very useful in solo or short handed sailing.
R. A. Manning
Winchers
My husband and I sailed our Typhoon for 20 years. We had blue rubber add on self tailing devices which I believe were called Winchers. They were really quite satisfactory. I'm not sure they are still available, but would recommend you try to find them before investing in expensive self-tailing winches. Hope this helps, Jo Chamberlain
Jack & Jo Chamberlain
- mahalocd36
Re: Winchers
We used these too on our previous 23' boat. I think we paid about $15-20 for them but that was a while ago. Definitely worth it. Boat US has them here:Jack & Jo Chamberlain wrote:My husband and I sailed our Typhoon for 20 years. We had blue rubber add on self tailing devices which I believe were called Winchers. They were really quite satisfactory. I'm not sure they are still available, but would recommend you try to find them before investing in expensive self-tailing winches. Hope this helps, Jo Chamberlain
http://www.boatus-store.com/webapp/wcs/ ... ctId=72183
but you can probably find them cheaper.
Melissa Abato
www.sailmahalo.com
www.sailmahalo.com
Thank you for your replies.
I have been searching for those "Winchers" for years! If they work you have saved me and hopefully many other sailors hundreds of dollars!
Thank you again for your help!
R. A. Manning
- Joe Myerson
Winchers
My boat came with a pair of Winchers, and they are a terrific substitute for investing in self-tailing winches, especially on smaller boats.
One little tip: The P.O. also left me two bottles of kids' bubble-blowing liquid. I couldn't for the life of me figure out what they were for, until I tried to stretch the Winchers over the heads of my winches.
I just couldn't make the darn things slip over the winchs. Then I remembered the bubble-blowing liquid. It was the perfect lubricant.
Keep it in mind if you get a pair of these rubber gadgets.
--Joe
--Joe
Former Commodore, CDSOA
--Capt. John Smith, 1627
winchers vs real self tailers IMHO
I have used winchers on two of my previous boats. Seraph came with them. I finally bite the big bullet and bought Andersen 12STs, self tailers for Seraph. There is no comparison when it comes to how well each one does it's job. I also single hand alot and the self tailers were one of the best things I've put on Seraph bar none. Winchers, while they sort of self tail, will lose grip very easily if the load on the line goes slack like in a puff that luffs the headsail.
I'd suggest you try and get a sail on a boat with self tailers and one with winchers and see what you think.
Randy 25D Seraph #161
Randy, how do you...
like your Andersen's? I'm thinking I'll outfit my project boat with them but wasn't real sure what size to get. Do you find you have plenty of power with the 12 ST's for singlehanded winching with a larger headsail? I think my project boat emphasizes the fore triangle a bit more (unfortunately. it was a last minute design change to suit the rules of the day rather than just good design sense) than the 25D even though they are pretty similar lengths/displacements.
Tod Mills
Tartan 26 project boat
Cape Dory admirer
Cape Dory admirer
