Loran C
- bottomscraper
Loran C
Loran?
In all due respect surely you aren't intending on using Loran to navigate a vessel you care about? For 8 years I was a factory rep and field Engr for Tracor's Loran and SatNav line of navigational equipment. Loran WAS OK back when it was the only wide ranging nav system. Don't get me started on all the anomilies that effect the Loran signal. With today's cheap GPS receivers, using Loran to navigate is a bit like using a a slide rule and just about as in-accurate.
Randy 25D Seraph #161
- Joe Myerson
For the paranoid--another advantage to Loran
Like Jack, I use my Loran as a backup to my Garmin GPS. But I recently read something very interesting (wish I could remember where, but I'm showing my age), that might explain why the government has yet to pull the plug on Loran altogether.
It's apparently very easy for sophisticated troublemakers to make a device that can jam GPS signals, but knocking out Loran would require destroying the individual sending stations.
If this information is accurate, Loran is likely to be around longer than originally predicted.
Also, even though there are all sorts of anomalies in the signal, guys in the commercial fishing business tell me that they still love Loran—it will get them back to precisely the same spot every time, they claim.
Just my two cents' (or less) worth on yesterday's technology.
--Joe Myerson
--Joe Myerson
Not only alive but well......
Homeland security and the CG are looking at combining a GPS and loran into a single unit. See the new Si-Tex unit at their web site. Under home land security the stations are getting new transmitters, etc. Cannot rely on a single system, each has its weakness and strengths. Many are finding the loran to be up and running during weather which knocks out GPS, thus they are carrying both on board. "Old" loran units are "hot", "hot", "hot"....shh...don't tell any one.....they are quite reasonable on EBay compared to GPS for a fixed station units and really nice when tied to an old laptop with free nav software from the web like Seaclear II.....Dana
Loran Article, 2004
http://www.fraudsandscams.com/Offshore/Loran/Loran.htm
An interesting article with another view of loran today...dana
Slide rules?
Randy:
With all due respect, why do you still use wind to power your boat? There are no fail safe high tech systems, period. That's why there are redundant systems on aircraft. GPS is great for telling you where you are on the surface, but a chart plotter is only as good as the chart it is based on, and we all know the problems there. I support Loran C as a backup system, and notwithstanding its inaccuracies, it is still quite likely to get me where I want to go.
Bill Michne
s/v Mintaka, CD 40
s/v Mintaka, CD 40
