Propeller for CD33
Propeller for CD33
Can anyone tell me what the original prop is for a CD33? Someone put an oversized 3 blader on and it is messed up. I would rather go back to the original design.
Steve
Steve
CD 330 Propeller
I don't know if this will help but I jus put a Michigan Wheel 14X10 3 blade MP propeller on my CD330 and it works great. I reach 2950 RPM at full power. The engine is rated for 3000 RPM at full power.
Neil
Neil
Neil Kozlowski
Ariel CD330 #146
Ariel CD330 #146
- s.v. LaVida
- Location: LaVida is a Cape Dory 33, Hull#40 Homeport of Olcott,NY
Propeller size
Steve,
With different engines, there is no standard propeller.
You'll need to match your engine/transmission to the prop.
Michigan wheel and other propeller mfg's. will do the math and suggest a prop size for you.
I think the best fixed blades for CD are the Cambell Sail Propeller. I don't have the www handy, but you can google for it.
Best of luck,
mike
s.v.LaVida
Best of luck,
mike
s.v.LaVida
- Zeida Cecilia-Mendez
props for 33
Steve, I currently have a the original 14/ 11 on Willow but have on order a Cambell Sailor, Neil (west by north enterprises) recommended a 14/9 for my Universal 30 with a Hurth 2:1 transmission.
I'm looking forward to less drag and more power with the new prop. Paul
CD33 Prop
Hi Steve,
Mike is correct - you have to match engine-boat- prop.
Evening Light (CD33 no. 38) was repowered approx. 1992 with a Westerbeke, W27A. The PO had a blade motorboat type that cost a 1/2 a knot boat speed under sail. I replaced it with a Bronze, 2-blade, 14RH10 (1 in. tapered shaft.) I get to hull speed without a problem
- am completely satisfied with my sailboat prop
Fair Winds,
Leo
S/V Evening Light Pine Isl. Bay, Groton, CT
(With all holes in the hull now filled)
Fair Winds,
Leo
- Frank Vernet
Michigan Wheel Corp. 15R11 Sailer 2-Blade
Steve,
We have the original Universal 5424 (24hp) and replaced the prop 2 years ago. The prop shop at the marina where we had Sirius for 3 years selected this prop as the best replacement:
Here's a link direct to the proper page:
http://www.miwheel.com/MIWheel/products ... p_sail.htm
Hope this helps.
Hope this helps.
