Stoves
Re: Stoves
Mike,
If you want a galley stove the low-pressure alcohol Origo series are great. I have one on my CD28 and prefer it to the pressurized Kenyon stove I have on my CD27. Alcohol fires are easy to extinguish with plain water, should the need arise and the low-pressure stoves don't flare up at all.
The Magma series of stern rail cookers are great if you can cook outside the cabin!
Best Regards,
Lyn Heiges
CD28 MOON CHILD
CD27 GUILLEMOT
lheiges@compuserve.com
Best Regards,
Lyn Heiges
CD28 MOON CHILD
CD27 GUILLEMOT
Mike Davis wrote: I am interested in purchasing a stove for my Cape Dory 25. Does anyone have any recommendations? Thanks, Mike
Re: Stoves
Hi MikeMike Davis wrote: I am interested in purchasing a stove for my Cape Dory 25. Does anyone have any recommendations? Thanks, Mike
We saw the new Simpson Lawerence stainless steel combination sink and two burner propane stove at the boat show last fall and ordered one from Defender. It is specifically designed for small boats. We are in the process of installing it now. With some modifications it will JUST fit on the port side replacing the existing sink and countertop.
jtstull@icubed.com
Re: Stoves
I replaced the original alcohol stove and oven on my CD30 with propane. Had a kerosene stove and oven on my previous boat. My experience has been great and I will never go back. Had many reservations, but with reasonable caution, it is fine. However, contrary to current practice, I did not install a solenoid valve. I just have a straight run of hose from the tank to the stove. When I'm finished cooking, I turn off the tank, let the fire go out, then turn off the stove. I believe a solenoid valve can get you in the bad habit of leaving the tank turned on, which could be disastrous if you have a leak, so if you turn the tank off anyway, which you should, you don't need the solenoid valve. I always pressure test it when I haven't used it for awhile. Don't be afraid of propane, its safe if you are.Lyn Heiges wrote: Mike,
Best Regards,
Lyn Heiges
CD28 MOON CHILD
CD27 GUILLEMOT
Carl Jones
Spanish Eyes- CD30 Cutter
GreatCells@aol.com
Re: Stoves
Carl,
Hanalei has the original Seaward Alcohol 2 burner with oven range. I'm just curious, where did you place the tank when you converted to gas?
Dave Stump
Captain Commanding
s/v Hanalei (CD-30)
Dave Stump
Captain Commanding
s/v Hanalei (CD-30)
Re: Stoves
Carl,
Thanks for the reply to my e-mail to Mike! I will have to look into the combination unit. I doubt we will be doing many souffles on board, but there are other things! I will have to look at the cabin layout for the CD30. I think it is about identical to the CD28 and I could try the same idea.
I operate our BBQ grille at home the same way you do your onboard stove. I have worked as a vounteer with the Montgomery County Maryland Fire and Rescue Service and KNOW what you are doing is SAFEST! We have to remind readers that the propane is heavier than air and thus, drains to the outside of the hull MUST be provided from the tank storage locker. I am sure you have these and a separate sealed locker for the tank(s).
Thanks Again!
Lyn Heiges
Thanks Again!
Lyn Heiges
Carl Jones wrote:I replaced the original alcohol stove and oven on my CD30 with propane. Had a kerosene stove and oven on my previous boat. My experience has been great and I will never go back. Had many reservations, but with reasonable caution, it is fine. However, contrary to current practice, I did not install a solenoid valve. I just have a straight run of hose from the tank to the stove. When I'm finished cooking, I turn off the tank, let the fire go out, then turn off the stove. I believe a solenoid valve can get you in the bad habit of leaving the tank turned on, which could be disastrous if you have a leak, so if you turn the tank off anyway, which you should, you don't need the solenoid valve. I always pressure test it when I haven't used it for awhile. Don't be afraid of propane, its safe if you are.Lyn Heiges wrote: Mike,
Best Regards,
Lyn Heiges
CD28 MOON CHILD
CD27 GUILLEMOT
Carl Jones
Re: Stoves
I like the one-burner Origo. The fuel is relatively safe, easy to store in large quantities (if you like), and the whole operation is real simple.
And you can use the stove as a cabin heater by placing a clay plant pot upside down on the burner.
everett@megalink.net
Re: Stoves
We bought a 2 burner Origo alcohol stove (unpressurized) and love it. It cooks fast and doesn't seem to flare up at all. This is our 4th season with it coming up and have never had a problem.
Cdchartley@aol.com
Cdchartley@aol.com
Re: Stoves
I have nothing but good things to say about the portable Kenyon single burner butane stoves, they use butane canisters about the size of a spray paint can,have electric starters and work great.They are also easily stored(13.5"x10.5"x3.5").they sell for about $60.Mike Davis wrote: I am interested in purchasing a stove for my Cape Dory 25. Does anyone have any recommendations? Thanks, Mike
I like the fact that they are portable,I've used mine in the cockpit to make coffee and at home while the power was out after the last hurricane.I've used mine for 2 seasons with no problems.
I also buy the refills from a restaurant supply house instead of a marine supply house,alot cheaper about $25 for a case of 12 cans
Re: Stoves
Hi Mike and Jerry...Jerry Albright wrote: I have nothing but good things to say about the portable Kenyon single burner butane stoves, they use butane canisters about the size of a spray paint can,have electric starters and work great.They are also easily stored(13.5"x10.5"x3.5").they sell for about $60.
I also have one of the little butane stoves..a Glowmaster, which is almost identical to the Kenyon. Have had no problems in 3 years of moderate cooking. These stoves are also used in restaurants and by caterers, and hold up well in very heavy duty use.
Harvey/ Ga
s/v Stargazer
harveywilson@compuserve.com
