Crowing While I Can - 1952 3 HP Evinrude Lightwin Running!
Ken Coit
Post by Ken Coit »
It works! Removed carb and found a dry float bowl even after adding fuel to tank and opening valve. Cleaned out every passage I could, made sure float valve was working (I think it was stuck shut), gave everything a shot of WD40 for good measure and reassembled. Made sure fuel was flowing from line to carb (low fuel in tank with a slightly tilted engine can cause problems here). Opened high and low speed jets to 1 turn each. She fired up rather quickly and settled down to running. Running in the barrel, I only got rough settings of the jets; high speed is 1/2 turn open and low speed is 1/4 turn open. Starts quickly and runs quietly. For 50 years old, I'd say that's pretty good. Owner to pick up soon, before it doesn't start again.
I created a set of notes for the owner. If anyone cares to have them, send an email. BTW, there is an Antique Outboard Motor Club; check it out at the link below. I have an idea they also discuss engines.
Keep on sailing,
Ken Coit, ND7N
CD/14 #538
CD/36 #84 Parfait
Hailing Port: Raleigh, NC
Sailing from: Beaufort, NC
parfaitNOSPAM@nc.rr.com
John H. Lockwood
Re: Crowing While I Can - 1952 3 HP Evinrude Lightwin Runnin
Post by John H. Lockwood »
Ken Coit wrote: It works! Removed carb and found a dry float bowl even after adding fuel to tank and opening valve. Cleaned out every passage I could, made sure float valve was working (I think it was stuck shut), gave everything a shot of WD40 for good measure and reassembled. Made sure fuel was flowing from line to carb (low fuel in tank with a slightly tilted engine can cause problems here). Opened high and low speed jets to 1 turn each. She fired up rather quickly and settled down to running. Running in the barrel, I only got rough settings of the jets; high speed is 1/2 turn open and low speed is 1/4 turn open. Starts quickly and runs quietly. For 50 years old, I'd say that's pretty good. Owner to pick up soon, before it doesn't start again.
Keep on sailing,
Ken Coit, ND7N
CD/14 #538
CD/36 #84 Parfait
Hey Ken:
This past weekend I saw a 1958 Evinrude 3 hrs serial #3026 02076
pretty good shape but they wanted $300. Is that too much?
jlockbosch@yahoo.com
