St.John,USVI
Dear CapeDory owners,
Just found your Web site.I need to document my CD 25D so I can visit the French Islands.If anyone has documented a CD 25D,and knows the net tons required for the Coast Guard,I would be very grateful.The best way to reach me is by e-mail:meander@pocketmail.com
thank you very much,
Lawrence
Anyone know the net tonnage of CD25D?
Re: Anyone know the net tonnage of CD25D?
To my knowledge the cd25d does not make the requirement for getting documented. I forget the formula, but it's had to do with the square footage of the boat. I believe the boat to pass, has to be able to displace 6 tons. That's a boat somewhere around 27'L by 8'W. Hope th is is helpful and some what correct.
Dave
CD25
Gloucester, ma
ddsailor25@ureach.com
Dave
CD25
Gloucester, ma
Lawrence Birch wrote: St.John,USVI
Lawrence
Please search on "documentation"
Lawrence,
Several CD/25Ds are documented. If you can search on "documentation" you will find several useful posts. If not, the short answer to your question is: 5 Net Tons.
Here is the info from one documentation certificate:
Gross tonnage: 6 GRT
Ken Coit
parfaitNOSPAM@nc.rr.com
Good luck,Lawrence Birch wrote: Net tonnage: 5 NRT
Length 25.2
Breadth 8.0
Depth 6.3
Ken Coit
Lawrence
>>I forget the formula, but it's had to do with the square footage of the boat.<<
It's a combination of beam, length and depth, so it's the cube not the square. "Tonnage" relates to the so-called cargo carrying capacity of the hull. The Coast Guard's documentation form shows how to measure each component.
By the way, the CG would save us all lots of time and effort (maybe save them time and effort, too) if they'd just give a list of models of production boats that have been previously documented.
Regards, Neil
neil@nrgordon.com
Regards, Neil
neil@nrgordon.com
Documentation Formula - Form Link Below
It is not a simple cubic measurement; it involves weighted measurements. See the link below for an interactive form.
FYI, as I calculate it, the CD/25D doesn't qualify per the formula, so take it with a grain of salt and rely on the previously documented boats' info.
I certainly agree that a simple list of previously documented production boats would be a large help to the CG and the public.
Keep on sailing,
Ken Coit, ND7N
CD/14 #538
CD/36 #84 Parfait
Hailing Port: Raleigh, NC
Sailing from: Beaufort, NC
Keep on sailing,
Ken Coit, ND7N
CD/14 #538
CD/36 #84 Parfait
Neil Gordon wrote: >>I forget the formula, but it's had to do with the square footage of the boat.<<
Regards, Neil
