I recently purchased a 1983 CD 25D. I moved from South of Annapolis to the Eastern Shore, about 35 miles all under power. The tank was filled on departure and would accept < 2 gallons on arrival. I realize the Yanmar diesel is ecconomic but this seems a bit much. Is there any way to determine the amount of fuel in the tank? There seems to be no fuel gauge and a dip stick can't be used due to the location of tank and filler.
Thanks for any suggestions.
Lee Schacter
leeschacter@comcast.net
Fuel gauge
Re: Fuel gauge
My 36 CD would get about 28 miles on 2 gallons, so I wouldn't be suprised if you are fairly accurate about the fuel consuption.Lee Schacter, MD wrote: I recently purchased a 1983 CD 25D. I moved from South of Annapolis to the Eastern Shore, about 35 miles all under power. The tank was filled on departure and would accept < 2 gallons on arrival. I realize the Yanmar diesel is ecconomic but this seems a bit much. Is there any way to determine the amount of fuel in the tank? There seems to be no fuel gauge and a dip stick can't be used due to the location of tank and filler.
Lee Schacter
Jerry Axler
cutter36@erols.com
Re: Fuel gauge
The single cylinder (8hp) Yanmar on TIA MARI (1979 CD27') used about a quart an hour at nearly full throttle. There should be an iformational plate on the top of the tank indicating capacity.
Hope this helps.
Mitchell Bober
RESPITE
CD330
Annapolis, MD
Hope this helps.
Mitchell Bober
RESPITE
CD330
Annapolis, MD
Re: Fuel gauge
Lee,Lee Schacter, MD wrote: I recently purchased a 1983 CD 25D. I moved from South of Annapolis to the Eastern Shore, about 35 miles all under power. The tank was filled on departure and would accept < 2 gallons on arrival. I realize the Yanmar diesel is ecconomic but this seems a bit much. Is there any way to determine the amount of fuel in the tank? There seems to be no fuel gauge and a dip stick can't be used due to the location of tank and filler.
Lee Schacter
We have also have a 1983 CD25D. I've heard that the Yanmar 1GM in a 25D gets about 250 miles to the tank. I think the tank holds about 12 gallons of fuel. At 35 miles and two gallons of diesel that's approximately 210 miles on a tank. Sounds about right to me.
Since your boat was built the same year as mine, you probably have the same fuel tank hardware. My tank has a fuel guage, but it's very difficult to look at. Open the port side cockpit locker and there's a removable wood access panel. If you take the panel off you can access the fuel tank, stuffing box, and the back of the engine. On Cricket, the fuel tank has a small fuel gauge on the top of the tank. The wood access panel has a small hole cut in it so you can see the gauge without removing the panel.
Hope this helps!
Bob & Becky Dugan
"Cricket" CD25D #092
Wayland, MA
bdugan@stepzero.com
