Whale Galley Pump Bracket
Joe Sankey
Post by Joe Sankey »
Has anyone replaced their metal bracket for the foot pump with a product you found in the aftermarket?
Joe Sankey
CD 30 Slow Dance
sankey@gulftel.com
John R.
Re: Whale Galley Pump Bracket
Post by John R. »
Joe Sankey wrote: Has anyone replaced their metal bracket for the foot pump with a product you found in the aftermarket?
Joe Sankey
CD 30 Slow Dance
Sort of Joe, I made a new one out of 1/4" X 4" aluminum "L" extrusion.
I cut the hole for the lever with a hole saw. Drilled the mounting holes, finished all the edges, then primed with zinc chromate, top coated with polyurethane. I replaced the pumps rubber foot pad with one I made out of teak that matches the original rubber one (which tends to split with time). I can send you a pic if you want.
Joe Sankey
Joe Sankey
CD 30 Slow Dance
John, that's a big help. Was the extrusion available at a source I might find locally or mail order?
Joe Sankey
CD 30 Slow Dance
John R. wrote: Sort of Joe, I made a new one out of 1/4" X 4" aluminum "L" extrusion.
sankey@gulftel.com
John R.
Post by John R. »
The aluminum extrusion is available at most decent aluminum supply houses. Just look in your local yellow pages under "aluminum".
I don't know about any particular mail order places but i'm sure they are out there. I get the stuff locally.
I'll e-mail you that picture.
Joe Sankey wrote:
Joe Sankey
CD 30 Slow Dance
Joe Sankey
CD 30 Slow Dance
Joe Sankey
Thanks, John. I'll look forward to the photo.
Joe Sankey
CD 30 Slow Dance
John R. wrote: The aluminum extrusion is available at most decent aluminum supply houses. Just look in your local yellow pages under "aluminum".
Joe Sankey wrote:
Joe Sankey
CD 30 Slow Dance
sankey@gulftel.com
Mystic Marine
Post by Mystic Marine »
Joe Sankey wrote: Thanks, John. I'll look forward to the photo.
Joe Sankey
CD 30 Slow Dance
If all you need is a little chunk of 4 x 4 angle in 1/4" thickness, let me know how long - we probably have some scrap around I could send you.
Duncan Maio
Mystic Marine
mail@mysticmarine.net
Joe Sankey
Joe Sankey
CD 30 Slow Dance
Duncan, thanks a lot for the offer. The bracket I removed is made from mild steel 4" angle; dimensions of each side = 4x4. It is also 4" wide. The largest I could find locally (fairly small town) today was a 2" extrusion. If you have such a thing I'd be happy to have it and pay accordingly.
Joe Sankey
CD 30 Slow Dance
Mystic Marine wrote: Duncan Maio
Mystic Marine
sankey@gulftel.com
