Motor mount and Bronze shaft source requested
David Rowland
Post by David Rowland »
Can anyone recommend sources for Volvo MD7A motor mounts? I tried Bushings, Inc, after searching the archives, and West Marine won't deal with them (?!). Also, while I'm doing my cutless bearing next month, I might have to replace the shaft. What is the best source for a CD30K bronze prop shaft?
Many thanks in advance for your help.
David
rowland@whro.net
Mike Quinlan
Re: Motor mount and Bronze shaft source requested
Post by Mike Quinlan »
David Rowland wrote: Can anyone recommend sources for Volvo MD7A motor mounts? I tried Bushings, Inc, after searching the archives, and West Marine won't deal with them (?!). Also, while I'm doing my cutless bearing next month, I might have to replace the shaft. What is the best source for a CD30K bronze prop shaft?
Don't deal with West Marine, Call Bushings inc direct. They will send you a catalog.
Any machine shop can build your shaft just hand them the old one and tell them to duplicate it.
Mikieq@erols.com
len
Post by len »
david
re shaft, in the boston area there are two propellor companies that do this - New England Prop 617-288-3132 and H and H prop 978-744-3806 - i am sure they can do it by UPS if necessary - you give or send them all the parts removed (prop, shaft, tranny coupling, stuffing box) and they clean everything up, make new shaft etc - i highly recommend NE Prop who have done this for me twice, cost several hundred dollars i believe but less than $500 and well worth it - your prop will be fixed so it looks new -
len
md.frel@nwh.org
