Our Cd 27(#228) has no tachometer and still is all original with Yanmar 8. How much throtle can you give it? Seems like if we do 4 knots the tough little engine is doing its best but the throtle is not all the way (pedal is not to the metal). We try to select a speed with minimum vibration but are reluctant to realy turn it on. What is the general opinion of a good cruising speed for this boat? Can you give it maximum throtle and not have it fall apart?
Doug and Jean on "Glissade"
douglas.powell@att.net
CD 27 cruising speed
Re: CD 27 cruising speed
I do not have a tach either on my Yanmar 8HP, CD27 Hull #66. I have, in flat or fairly flat water, pushed the boat along at about 5.5kts with out feeling that I was pushing her too hard. I generally will not go beyond what I "think" is about 75% power. In a sea I will get about 4.5kts. I recently had the engine realligned and vibration is reasonable.
aldajon@aol.com
aldajon@aol.com
I have CD27 hull#71 with the same engine (YSB8) except that previous owner switched to a 3 blade prop. He reported he gets extra 1/2 knot and better push against headwinds.
There is a lot of vibration and noise with this engine (I think I need new mounts and an alignment), but I find that there is a reasonable "sweet spot" where the throttle is just a wee bit lower to the floor of the line with the gear selector in fwd position.
At the "sweet spot" I get 5 knots in flat/calm conditions, and 4.5 in modest headwinds&seas.
I can get 5.5 knots by flooring the engine...nothing breaks but the note of the engine definitely becomes sort of a "roar" that just plain sounds like it's working hard.
I sometimes run it all out for a little while to get out of a bind, like running an inlet or making a timed bridge opening. Wouldn't want to do that for a long period, if only to make the trip more pleasant.
Eventualy, if the ol YSM8 ever comes to need major work I'll repower with the Yanmar 2GMF...
Jeff
Jeff.Schmoyer@IFF.com
Jeff
Doug,Doug Powell wrote: Our Cd 27(#228) has no tachometer and still is all original with Yanmar 8. How much throtle can you give it? Seems like if we do 4 knots the tough little engine is doing its best but the throtle is not all the way (pedal is not to the metal). We try to select a speed with minimum vibration but are reluctant to realy turn it on. What is the general opinion of a good cruising speed for this boat? Can you give it maximum throtle and not have it fall apart?
To answer your question "how much throtel CAN you give her?" I will tell you that I have experienced "RUN-AWAY" on my Yanmar 8.
I sail WINDCHASER hull# 133 and have on several occasions had the original YSM8 go to MAX throtle uncontrollably! It is a very scarry thing to experience. However it demonstrates to me that it can take A LOT OF THROTLE.
I believe it says much for this engine that it will take that and that we are having this discussion about the original power for hull #s 133, 71 and 66.
