Internallizing (sp) Reefing Lines
Post by Bill »
Hello to All
I am tired of seeing my reefing lines drooping along the boom everytime I go out and am considering installing exit plates and running the lines through the boom.
Has anyone done this? Does anyone have any comments on this project?
Thanks in Advance
cd25d@rhapsodysails.com
Re: Internallizing (sp) Reefing Lines
>>I am tired of seeing my reefing lines drooping along the boom everytime I go out...<<
The simpler solution to eliminating the droop is to take all the slack in when dropping the main. I do this routinely, taking in the full first reef, as it tames the main considerably, particularly the part that's out of reach due to the dodger.
If the line runs internally, you'll still have the droop when you drop the main. It will stay there unless you take the slack out.
Regards, Neil
cdory28@aol.com
Roger
Post by Roger »
Me too: ditto on my outhaul line. Suspect this involves replacing the end cap on the boom with something containing sheeve(s) and then drilling an exit slot near the mast end next to the cleats.
Any tips or suggestions?
Roger
Bill wrote: Hello to All
Thanks in Advance
Post by Bill »
Roger
Here's a link to <a href="http://www.dwyermast.com/BOOMS/dm375bm.htm">Dwyer Mast</A> and their boom section has the same deminisions as does the Spartan boom. Will it fit???I dont know. But is worth the eamil to find out.
