Does anyone know if the Simrad wp30 (navico wp300cx) or the Raytheon st4000+ wheel pilot will work with the Edson worm gear steering on my '79 30 ketch?
Seems it would be mounted backwards from how it would mount on
a pedistal. Can these things be told to "think" backwards? If not, what are my options?
Thanks.
-- alonzo
ltjones @ ualr . com
autopilot for edson worm gear?
Re: autopilot for edson worm gear
Alonzo,
I have zero experience with the worm gear or the autopilots you mention, but I can tell you that it is very likely that if you reverse the wires to the drive motor, the unit will "think backwards."
Ken
parfait@nc.rr.com
Ken
alonzo jones wrote: Does anyone know if the Simrad wp30 (navico wp300cx) or the Raytheon st4000+ wheel pilot will work with the Edson worm gear steering on my '79 30 ketch?
Thanks.
-- alonzo
parfait@nc.rr.com
I don't know either, but a few pieces of the puzzle that may help. . .Ken Coit wrote: Alonzo,
The aft end of the Edson worm gear shaft is keyed to accept a sprocket for a chain-drive autopilot. The Edson tech guy seemed to be ready to discuss options. I would check them out for suggested approaches. (Yes, the worm-gear steering assembly is still available.) Let us know how you solve this problem . . . my semi-elegant solution was to buy a different boat. . .
Good Luck, Dale
majortest@earthlink.net
Re: autopilot for edson worm gear?
Hi Alonzo...
I dont have any experience with such rig ...auto pilot for worm gear like cd30 s...but during N.E randezvous i noticed one cd30K with such an arrangement and i believe could have been HEATHER ANN and if so..
LEO MC DONALD can help you out...cheers/mike.
compinchecd30@yahoo.com
Thanks Mike, et al:mike wrote: Hi Alonzo...
I've ordered a Simrad WP5000 belt drive autopilot (Boat/US $500). I figure that I can make that work. Enquiries to Edson,
West Marine (no longer sells simrad and Simrad yielded no info about running the self contained unit backwards.
-- alonzo
ltjones @ ualr . edu
Alonzo: I installed a Raytheon 4000 several years ago works fine and I wouldn't want to cruse without it.alonzo jones wrote: Does anyone know if the Simrad wp30 (navico wp300cx) or the Raytheon st4000+ wheel pilot will work with the Edson worm gear steering on my '79 30 ketch?
Thanks.
-- alonzo
good luck
Fred
fscaglio@optonline.net
