I have been removing my staysail club and stay when cruising for just the reasons you suggest. i.e., deck clutter which prevents being able to carry my dink on board, and inhibits use of anchor windless.
HOwever, I do miss the flexibility of the cutter when sailing.
Maybe I need to rethink my cruising habits.
The real issue requiring solution is dink stowage on the bow. I can tow it when I get to the Bahamas Bank, but I don't like the idea of towing it when I am in open sea, particularly the Gulf Stream. Since I have a Caribe inflatable, RIB, dink substitution doesn't seem to be an economical option. Perhaps I could deflate the dink and stow it behind the mast. Not a perfect solution since the dink does double duty as life raft.
HOwever, the Cape Dory 30, whether cutter or sloop rigged, is clearly the best sailing vessel I have ever owned. (until i got the 30, I thought the same about my CD 27). This is my fourth boat and hopefully my last.
I appreciate your comments and those of L. Demers and the others. I have learned a lot since I have been following this board.
Will
"Jambalaya"
CD 30, hull # 358
Tom wrote: Chris, I've been out sailing and just got back, so am joining in late here. One part of your question not directly addressed is the deck sweeper portion. You get a lot of sail area and drive from the foot of the sail so that's why people opt for a deck sweeper rather than a high cut yankee in spite of the disadvantages such as poor vision. I have a 140 deck sweeper on mine and wouldn't change to anythinig else. I have to use a pennant to raise it enough to clear the pulpit. If you're doing any serious cruising, I wouldn't remove the staysail stay. You'll find you use that club footed staysail a lot. It's the thing that makes the cutter rig the preferred rig of cruising boats -- all those sail choices and combos, and well worth the extra lines and deck clutter etc that sloop sailors complain about. JMHO
Chris Schnell wrote: Was wondering what the general concensus was about the design of a new roller furling headsail for a CD30 Cutter....should it be a traditional Yankee cut, modified Yankee cut, deck sweeper, greatest size (e.g. 135%), etc. Thanks.
Chris Schnell
s/v MADNESS III CD30 #235
Southport, NC
whildenp@flinet.com
