We have had a lot of rain lately and I noticed some water damage in the teak boards at the companion way I followed Jim's direction and pulled off all the teak boards. There was not much bedding compound. They didn't take long to remove, only about an hour and a half. I brought them all home and stripped and sanded them last night.. Today I will go back to the boat and install them. I have a few questions: Some of the boards look perfectly good,why should I strip them? since these boards have been previously varnished Why should I thin the varnish so much like advised, 50/50 first coat, 30/ 70 2nd coat etc. I wonder if I need to fill the old holes for the fasteners or just reuse them. finally, it looks like that originally the boards were varnished in place. I thought of varnishing them on the bench before installation,at least one or two coats, That curved board has a dark mark where a name plate goes so i won't try to sand it off.
Post subject: Companionway drip.....drip.....drip (Jim's thread) I don't know how to put the link
Leoma companionway boards
- name plaque III.JPG (1.92 MiB) Viewed 975 times
- teak boards.jpg (2.6 MiB) Viewed 975 times
Re: Leoma companionway boards
Re-use the old fastener holes if possible. If you feel the need to add a couple extra, feel free. Since you have everything in your workshop I’d take advantage of the opportunity and put a few coats of varnish on while access is easy. After you bung the fastening holes you’ll have to add a couple more coats once everything is back in place.
Those pieces of trim which appear to be in fine shape may not look as good as the rest in a short time so my advice would be to use this opportunity to refinish them all, at the same time, for appearances sake. Also use plenty of the caulk/bedding of your choice when you reinstall. The last thing you want is to not fill all the gaps/voids and be back where you started.
You will be so happy with yourself when drips are a distant memory. Nice job!
Got it all back together. It was easier than i thought. I have a couple regrets: I put a big blob of calking on the inside corners. Im afraid it might not be good enough. I thought I saw moisture the next morning. I should have put two or three horizontal beads across those corners. We’ll see. Also The store bought wood plugs are too light. I dont have a drill press and its kinda hard to mane them with a regular drill. Well now I can confidently remove and refinish the combings. I want to put a cap on them like “FarReach”
- B1CC0089-6817-47A4-A325-AFF071CC14EF.jpeg (2.94 MiB) Viewed 934 times
JD
Looks good. You are really getting everything nice and tidy. How's your shoulder?
Thanks. John. New shoulder is great. The other is horrible. Might not go to Mexico If I go it will be Feb 15. Same as last year. I cant even get good sleep at home. I need to get up every two hrs snd put pain creme and take tylonol
