CD27 re-power to Beta
Paul D.
Re: CD27 re-power to Beta
Post by Paul D. »
Hey Tom, hope you get some sailing in yet.
White oak is good stuff. I would be sure to get from the yard how they will be treating it as it will be in the bilge and how they recommend maintaining it. They could encase the who stringer in glass, epoxy or simply treat with preservative, so I would understand their concept for it and what that means for maintenance.
gonesail
Post by gonesail »
agree. if white oak was good enough for "old ironsides" it should serve you well in your engine room. a few coats of bilge coat should seal it nicely. a buddy of mine repowered his older catalina 30 with a beta and loves it.
karonoko
Post by karonoko »
Almost done with the repower. Had to drill new hru hull on starboard for raw water. Now wrestling with muffler location
T. Duffus
Is that oak raw or was a sealer applied? The engine is a piece of art….
sailor_grant
Post by sailor_grant »
Can you post picture of back of mount?
Did you use lag screws or did you just get a longer bolt and tap into mild steel plate under the fiberglass?
