Main Sail Cut Back
jmaue
Main Sail Cut Back
Post by jmaue »
Is anyone familiar with this term? Spoke with a loft that has a mainsail from a CD28 and said it was made with a cut back and likely intended to roll around the boom when reefing. Did Cape Dory design such a thing on the 28's?
Chrisa006
Re: Main Sail Cut Back
Post by Chrisa006 »
I know they made it for the CD25 at one time.
Chris Anderheggen
CD25 "Windsong"
Catalina 30 "Kestrel"
Catalina 387 " Parrot Cay"
Credo quia absurdum
Kailua Kid
Post by Kailua Kid »
If “cut back” means removing sail area at the leach, that would not only limit performance by reducing sail area but would move the center of work forward in relation to the center of lateral resistance, which would tend to reduce or remove weather helm. Maybe pass on that sail?
I believe the sailmakers term “cut back” refers to the material which has to be tailored to accommodate the gooseneck fitting and where the first sail slide enters the sail track.
A “roachless” main has the leach tapered to facilitate roller reefing, if I recall correctly.
jmaue
Post by jmaue »
Jim,
What you stated sound just what the loft manager stated. I'm not at all familiar with this and so I didn't present to the group properly.
So how does this work? Will this sail perform properly on a "non roller reefing"? Of do I keep looking?
