Could I connect a S2000 autopilot direclty to bank battery
Hi
I tried to connect the electrical cables that connect to the Raymarine S2000 autopilot’s connector to the DC distribution panel of my CD25D. But I could not figure out how to do it. Would like to know if anyone has tried to connect it directly to the battery with a 12 A fuse for protection.
Carlos
Carlos
Re: Could I connect a S2000 autopilot direclty to bank batt
Carlos:Of course you can connect direct to the house battery, but for a couple reasons that is not the recommended set up, even if fused (and especially if you have any other connections to electrical or electronic equipment on that battery).
Thanks!!!. I just thought one can use some kind of marine thermal circuit breaker connected to one of the battery bank and connect the S2000 autopilot's cables from there. I guess will need to deal with that bunch of entangled wires in the distribution panel.
Carlos, because autopilots use more power they usually have their own circuit. I have mine on the same circuit as the instruments but I have very little power as my instruments on that circuit are few and create minimal draw. Plus my chart plotter, probably the biggest draw, is on a separate 12v plug circuit. Either way it is good to have it wired through the panel with the right side wires for the load and distance round trip. Autopilot positive wiring would be light green.
Our CD electrical installations were one of the less 'tastefully' done systems of the brand, but I've found them generally solid. Good luck!
Thanks Paul!!! I might end up adding an additional panel (subpanel). Just need to figure out how to do it.
Carlos
Carlos
I have my ST 2000 wired directly to the battery. It is on fused line. It and my bilge pump are not connected through the master switch and the circuits are always "live" . Works for me.
Walter R Hobbs
CD 14 hull # 535, Grin
CD 27 Hull # 35 Horizon Song
Lincoln, RI
Lincoln, RI
Hi Walter,Walter Hobbs wrote:I have my ST 2000 wired directly to the battery. It is on fused line. It and my bilge pump are not connected through the master switch and the circuits are always "live" . Works for me.
Just curious what the reasoning is for keeping the Autopilot live at all times. The bilge pump I understand if you use an automatic activating switch.
Keith
- Dick Kobayashi
Here is what I did and it worked well for 19 years. Tap into a low load circuit like the one that lights up the compass or similar. I did this and it worked fine for along time. Use larger dia wire to minimize voltage drop. The area behind the panel will always be a rats nest, forget it and direct wiring to battery has its own problems
Dick K
CD 25D Susan B #104
Mattapoisett, MA
CD 25D Susan B #104
Mattapoisett, MA
Hi
Thanks for all the valuable suggestions. That's what I like the most from this board , their great feedback.
Carlos
Carlos
