I would like to upgrade the mast winch used for the main halyard on my CD-25D. It is the original number 6 winch and I would like to go at least a “7” winch. I would prefer not drilling new holes in the mast, so I guess my question is: do the 6 and 7 winches use the same mounting holes. If not, then I guess the alternative is to lead the main halyard back to the rear of the cabin and install whatever winch I can afford and a clutch.
Anyone have any experience with this?
Thanks in advance to any help!
CD25 mast winch
Re: CD25 mast winch
You didn’t specify the make of the winch so I presume it’s a Lewmar. These schematics indicate that some components are the same but the spindles are not. It is safe to assume they would have a different mounting pattern but we all know what happens when we assume.n5ama wrote:I would like to upgrade the mast winch used for the main halyard on my CD-25D. It is the original number 6 winch and I would like to go at least a “7” winch. I would prefer not drilling new holes in the mast, so I guess my question is: do the 6 and 7 winches use the same mounting holes. If not, then I guess the alternative is to lead the main halyard back to the rear of the cabin and install whatever winch I can afford and a clutch.
If there is a marine consignment shop near you you may be lucky to find one and verify the dimensions.
http://www.fawcettboat.com/images/Lewma ... dard-6.pdf
http://www.fawcettboat.com/images/Lewma ... dard-7.pdf
Re: CD25 mast winch
Thanks Jim!
I'm fairly certain the mast winch is Lewmar. I'll have to check to be sure. I've got bronze #7 winches for the jib sheets in the cockpit but I think they are not Lewmar. I haven't pulled them down for cleaning and relube but will check the pattern on those when I do. I have no problem going to the mast to raise the mail and have to be there anyway to lower it because the boat isn't equipped with lazy jacks (yet).
