Unusual Boarding Ladder
Capt Rich
Post by Capt Rich »
Does anyone else have this type of boarding ladder? I was wondering how functional it is, it seems like a lot of stress to put on one stanchion.
Happily sailing Cape Dory 28 hull# 343
On the Great Lakes out of our home port of Huron, Ohio
Carl Thunberg
Re: Unusual Boarding Ladder
Post by Carl Thunberg »
I think the lack of responses on this one is an indication no one has seen a boarding ladder like this. I'll reserve judgment on whether it puts too much stress on one stanchion. That tubular steel hoop with the rubber pad just might keep the boarding ladder oriented correctly to keep stanchion in compression. I will say, I've seen a lot simpler boarding ladders that work just fine. I'm curious what happens to the hinge after a couple years exposed to salt spray.
Cathy Monaghan
Post by Cathy Monaghan »
I’ve not seen any like that. They are usually stern-mounted folding ladders, or mounted from the T-track on the side of the boat like this one:
CDSOA Associate Member #265
Rahway, NJ
Raritan Bay
Tod Mills
Post by Tod Mills »
I've seen pics of ladders like that but never in person. Here, Patrick Childress discusses his at 17:30 in this tour of his Valiant 40: https://www.youtube.com/watch?v=vT6qZtij6us
As an engineer, I'd say your observation about the design are spot on. There is nothing inherently wrong with the principle but the extra loading on the stanchion would need to be taken into account in order to ensure no problems. I would be surprised if what we are seeing there were as solid as I personally would want it to be, starting with the stanchion/deck connection and lack of an athwartships brace. More than one stanchion base (even without a ladder) has had leaking issues; adding a ladder certainly doesn't help.
Tod Mills
Tartan 26 project boat
Cape Dory admirer
Capt Rich
Post by Capt Rich »
Tod thanks so much for posting the link to that video. Patrick Childress’s boat was great. The ladder seemed fine after twelve years of cruising, serious bluewater cruising. I sent Childress note asking him about his experience with his swing ladder. Thanks again.
Capt Rich
Post by Capt Rich »
Hey Tod I live in Huron, Ohio
Tod Mills
Post by Tod Mills »
Capt Rich wrote:Hey Tod I live in Huron, Ohio
Small world! I live down in Ashland but sail out of Sandusky....or will again after I get my project boat back in the water.
Tod Mills
Cape Dory admirer
Capt Rich
Post by Capt Rich »
Thanks everyone for your input. I have decided to keep ladder for now based on a recommendation from a bluewater cruiser using the same ladder. At a suggestion of CDSOA forum member Tod I watched a YouTube video of Patrick Childress. Patrick got back to me; forty years with no issues and no leaks from bedded bolts on his forty year old Valiant 42’ currently sailing around the world.
Keith
Post by Keith »
Hi Capt Rich,
I just viewed the video of the Valiant 40 and it does have athwartship braces that attach to the toe rail which would explain why it has worked without leaking or other damage. On yours it looks like it would be difficult to add them but maybe you can come up with something.
Keith
