One area that I would like to learn more about is brush selection. I imagine this is one area not to "cheap out" on if you want to get that gorgeous varnished teak on the coaming boards.
Steve is correct. I think the original spartan coamings cleat would require a small adapter (if you added the same thickness teak cap I used) which could be made from a piece of teak or better yet 1/4” silicon bronze.Steve Laume wrote:While John's solution of capping the cockpit combings with raw teak is elegant and effective, it would not work well with the original Spartan cleats. It will require additional masking and some sort of treatment when things get refreshed.
I have used brass, half oval, in a variety of locations where wear is a problem. I haven't done the combing tops, yet but do have the material. That means I have technically started to do it. A couple of advantages of using brass are that it can simply be removed when it is time to refinish the bright work and it wears very well. I have used it in different locations where the teak could see some chafe. It comes in different widths so you can get whatever size, suits the location it is intended to protect. It looks right on our boats. It is easy to work with and also easy on your lines and is probably cheaper than adding additional teak.
The teak cap certainly adds some strength to the combing boards and works well for John because he is using different cleats. It just might not work for all of us, Steve.
Pish posh. We are not talking about solving world hunger. Epifanes is a good varnish. All ya have to do is tape. And sand between each coat. Lightly. Apply varnish with a foam brush. Repeat till you're satisfied. The more detailed you are the better it will look. True of most anything you do in life.Sea Hunt Video wrote: From all I have read Epifanes is one of the very best varnishes on the market. It is, however, expensive and requires careful, detailed prep, and many, many coats. When done right it is breathtaking.
