cape dory 25 lines plans
Does anyone know where I can find lines drawings for a Cape Dory 25? I'd like to make a half model of this boat and haven't had success in my online searches for plans.
Thank you,
Dan
Thank you,
Dan
Re: cape dory 25 lines plans
Todd Dunn microyachts. Somewhere in Maine
I don’t think they are originally from CD but look good enough for a model.
Pete
Pete
Thank you! I will check it out.
Dan
Dan
I got a set of lines drawings, for the CD-30, from Todd, a few years back. He only had a elevations and sections. that works if you are making a model by taking sections and making frames. I wanted to do lift models and for that you need, elevation and plan views. I had some experience in drafting lines so I was able to create the plan view from the other two perspectives.
It is very generous of him to share these plans, Steve.
Thank you, Steve. I would need the half-breadth and sheer plans to build the half model. I will keep searching because I'm certain the plans must be out there somewhere.
Dan
Dan
Dan
Email Todd
I don’t know if the plans he sent me are what you need to build a half model.
I believe he made them for someone who was going to build one.
It was a very nominal charge for the plans that I had framed.
Sounds like a nice winter project.
Good luck
Pete
Email Todd
Good luck
Pete
Someone could make a brisk business doing LIDAR scans of boats on the hard. Hell, you could even print your own boat hull on a 3-D laser printer. With the right paint job, it could look very nice. Who needs craftsmanship when you have a drone? (yes, that was sarcasm )
I think I'm hard aground on the island of knowledge when it comes to finding these lines drawings.
Dan
I can take my framed drawing to one of those copy franchises if you want.
16 by 12 comprised of 3 drawings and rudder.
Pete,
Thank you for the kind offer. Are these three drawings the half-breadth, profile and body plans?
Dan
Dan
Dan send me a pm with your email address and I will send you a quick picture to determine Todd’s drawing will work for you.
If it is I will be glad to send you the full size copy
Pete
Pete
