Engine oil stain on cabin sole
frankfurder
Post by frankfurder »
Anyone come up with a solution to remove or reduce a cabin sole oil stain from sloppy bilge cleaning? Existing sole is teak veneer with no finish.
Joe CD MS 300
Re: Engine oil stain on cabin sole
Post by Joe CD MS 300 »
Clean as best you can with mineral spirits or turpine then oil the entire floor with teak oil.
Anthony P. Jeske
FLYING CIRCUS
Post by Anthony P. Jeske »
Hi:
I used teak cleaner (oxalic acid) on my cabin floor and eliminated dirty engine oil stains. No sanding of the thin veneer is needed.
Three coats of varnish was then applied, which protected against future staining.
Since the cabin floor is not in the sun, the varnish doesn't break down.
Good Luck,
Tony Jeske
