Offered for $24,900, reduced from $29,000. This 1983 Cape Dory 31 was designed by Carl Alberg and is production #2 of only 89 built between 1983 and 1985! She was originally rigged as a cutter, but has been sloop rigged for at least the last 7 years. She is powered with a 21hp Universal diesel engine.
"Ellie" has a bright, easy-clean, fiberglass deck with molded non-skid. She has lots of great teak details, including coamings, grab rails, and drop boards that give Cape Dory yachts their signature traditional look.
Above deck, the cockpit is covered by a custom-built, stainless steel bimini top with a new Isinglass dodger with canvas covers. At the bow, you will find a dual anchor roller, the roller furler, a pair of deck cleats and a stainless steel bow pulpit.
Below deck, you will find a charming, tidy layout. The teak interior is flawless and obviously well-cared for. The U-shaped galley is situated to Starboard, with the head to Port. The galley boasts plenty of stowage, a 2-burner stove and oven, top-loading refrigeration, and double stainless steel sink.
Moving forward into the salon, you will find built-in sofas on both sides of the cabin. Above both settees, there is ample stowage for books, gear, and any must-haves while aboard. The table amidships is a beautiful and simply engineered butterfly table that folds away when not in use. All of the upholstery has been updated and is in impeccable shape.
The v-berth is forward of the salon, and continues the traditional teak ambiance. Stowage is offered on the port and starboard sides, with drawers to port, and a hanging locker to starboard.
If you are in the market for a Cape Dory or comparable vessel, come see this boat! She will not disappoint! Seller is open to offers, so don't be shy!
Seller to provide $1,000 toward shipping.
Julie Tijerina
St. Barts Yachts
Jacksonville, FL
904-264-9100
julie.tijerina@st-barts.com
Boat Name
Ellie
Specs
Designer: Carl Alberg
Flag of Registry: United States
Keel: Other
Hull Shape: Monohull
Dimensions
LOA: 31 ft 0 in
Beam: 9 ft 1 in
Maximum Draft: 4 ft 9 in
Displacement: 11500 lbs
Bridge Clearance: 45 ft 0 in
Engines
Engine 1:
Engine Brand: Universal
Engine Model: 25
Engine Type: Inboard
Engine/Fuel Type: Diesel
Drive Type: Direct Drive
Tanks
Fresh Water Tanks: (84 Gallons)
Fuel Tanks: (20 Gallons)
Holding Tanks: (28 Gallons)
Accommodations
Number of single berths: 4
Number of cabins: 1
Number of heads: 1
Seating Capacity: 4
Deck and Hull
2 bow chocks
2 cleats at bow
2 cleats at midships
2 opening deck hatches
3 cleats in cockpit
3 Cockpit Lazarettes
9 bronze portlights
Bilge Pump - Rule 300
Emergency tiller
Manual bilge pump in cockpit
New Lifelines in 2018
New seacocks
Stainless Steel Stantions (4 new in 2018)
Teak grabrails
Shiny, clean topsides
Electrical
110 outlets/GFCI in head
30 Amp/125V Shore Power
Solar panel
Xantrex Battery Charger new in 2014
Electronics
Autohelm (needs calibration)
Cybernet Speakers in Salon
Datamarine Depth/Speed/Distance
Galaxy Compass
Garmin GPS 128
Heel Indicator
Standard Horizon VHF
West Marine AM/FM Stereo w/Bluetooth
Ground Tackle
200 ft of anchor chain
Aft anchor and chain
Double Bow roller
Plow Anchor at bow
Engine
Universal 21 hp Diesel
New Raw Water Pump 2016
Accommodations
V-Berth cabin
Butterfly-style salon table
Canvas Bimini - new
Canvas enclosure with side curtains
Cockpit Cushions
Isenglass Doger - new
Manual head
Newport Propane Heater
Propane locker w/2 tanks
Seating for 6-8 in salon
Shower faucet in head sink
Starboard settee converts to double berth
Teak interior in flawless condition
Tons of stowage
Updated upholster
Water Heater 6 gal
Galley
2 burner stove with oven
Hideaway Trash
In-counter dry stores
Refrigeration
Trident gas control
Rig and Sails
130% Genoa
4 winches in cockpit
Additional jib (150%)
Additional staysail
Genoa Tracks and Cars
Jib Blocks in cockpit
Lazy Jacks
Mainsail
Mainsheet traveler
Fittings installed to convert back to cutter rig
Schaeffer Systems Roller furling headsail
1983 Cape Dory Sloop, Jacksonville, FL $24,900
- Galley 1.jpg (1.41 MiB) Viewed 490 times
- Cockpit.jpg (2.59 MiB) Viewed 490 times
- Topsides Starboard.jpg (1.74 MiB) Viewed 490 times
