CD 25 Water Tank issue
Keyscaptainadam
Post by Keyscaptainadam »
Recently I discovered a bilge full of fresh water and an empty fresh water tank.
unable to source the leak (not hose, not fitting, not anything visible) I have determined the plastic tank must have developed a crack/leak.
My plan was to remove/cut away the top of the tank and insert a bladder to take the shape of the tank.
anyone have dimensions/capacity of water tank in CD 25?
Adam
SV Velella
S/V Velella .... CD 25 moored in Cold Spring Harbor, Long Island, NY
Sailing long island waters since 2009
http://www.adam-waywell.squarespace.com/
Prairiesailor
Re: CD 25 Water Tank issue
Post by Prairiesailor »
New to the site, did you fix your problem or get the answer for the size of the water tank? Mine was 18 gallon. You can see what I did on you tube. My channel is whitetail.
Keyscaptainadam
i purchased a new 18 gallon tank and installed
