Would like to get advice on best way to install chain plate on port side for a cape dory 28.
Appreciate any photos of chain plate installation.
Leaning towards using rectangular piece of G10. Fiberglass to hull then tie the side stays somehow to the G10. Maybe use turnbuckles.
arch
Urgent. Need help on cape dory 28 chain plate.
Moderator: bobdugan
Re: help cape dory 28 chain plate no one ????
Any advice appreciated
Re: Urgent. Need help on cape dory 28 chain plate.
Searching past discussions will bring up many posts about retrofitting chainplates.
JD-MDR posted a picture of a G10 backing plate in his post from 5/21/17 (http://www.capedory.org/board/viewtopic ... 10#p195550):
I would avoid any construction that involved turnbuckles below the deck.
- Markst95
Have you seen another members site about his 28? http://www.sbastro.com/FeNIX/Projects/P ... temsFS.htm
- Bob Ohler
Will Keane, who used to run the quality control department at Cape Dory, recommends G10.
Bob Ohler
CDSOA Member #188
CD30B, Hull # 335
sv Aloha Spirit
CDSOA Member #188
CD30B, Hull # 335
sv Aloha Spirit
