backing plates for chainplates
Why are there no backing plates on my 1979 CD28 chainplates?
Re: backing plates for chainplates
My guess would be some PO "repaired" them... That does not look like it came from the factory that way.
I'm curious if a survey had been done? This seems worthy of a paragraph or two.
- Location: Prev. Islander 36 #425 Fyfe & Drum Current: Cape Dory Typhoon #930
I just removed the chainplates on my new (to me) Typhoon, so my boyfriend can make me a set of backing plates. Why these were never strongbacked in the first place is mind boggling. It was a right pain in the butt to unscrew everything.
Thanks for the responses. My further research results in my belief that the backing plate may be a long piece of steel that goes under all three chainplates. It also may be attached to steel vertical members, all fiberglassed over into the hull and deck. It may be original and done by Cape Dory when the boat was built in '79. I did have the boat surveyed by a SAMS certified guy before I bought it last Spring. He said, "Shroud chainplates bolt through the hull/deck flange. All appear to be secure, with no leaks." I didn't, at the time, do the acrobatics necessary to get a look at them below, relying on him. I finally did yesterday as part of a Spring check of things. I'm almost sure, but not positive, that the 1980 CD25 I previously owned had visible backing plates. That's why I was surprised by the nuts-on-glass appearance of mine on the CD28. I don't know about Typhoons but you might want to do more research and check carefully to see if it has backing plates hidden by fiberglass.
mgphl52 and Hilbert. If you don't mind my asking, what do your shroud chainplates look like from below?
- tjr818
A good Magnet should help you determine if there is mild steel embedded in the fiberglass.
Best of luck.
Best of luck.
In 1976, they were using mild steel with rebar down the sides:riveredge wrote:mgphl52 and Hilbert. If you don't mind my asking, what do your shroud chainplates look like from below?
looks just like my new 25 (1974)
The steel/iron rybar backing is in between the glass and the deck as in the original post. I took off the nuts and added new backing due to the original steel decaying....not a great solution, but hopefully a stop gap.
Yours looks great compared to mine
John H.
Mattapoisett, MA
1980 Weekender Typhoon " Sailing Shoes"
Mattapoisett, MA
- tjr818
On our 1980 the chainplate backers are mild steel and the steel is exposed not embedded.
Please forgive the inclusion of the mud-dauber home, that was the first time I ever saw it, it is gone now.
My CD 22 has exposed steel backing plates. Not sure of material but can check.
______________
Rick
1984 CD22
Rick
1984 CD22
