Glue remover
Scott B.
Glue remover
Post by Scott B. »
I have successfully removed old tape glue (duct tape in particular. Please don't ask how it got there) from stainless steel pulpit and stern rails and the aluminum mast, although it takes some elbow grease, with mineral spirits. But I now have some stubborn tape on the desk fiberglass (used to hold done the hatch during a road move). is mineral spirits still the answer or will that be aggressive to the glass? what else can I use if I need to?
swpatooty2
Re: Glue remover
Post by swpatooty2 »
You might try GOO GONE, made by Magic American Products, Cleveland. www.GooGone.com.
Comes in an 8-oz. bottle, and is available in hardware stores, and possibly elsewhere. Test-try it in a remote spot.
Worked for me.
Ken
Re: Glue remover
"Goo Gone" works and won't harm the fiberglass.
Sea Hunt Video
Re: Glue remover
Post by Sea Hunt Video »
WD 40
Scott B.
Re: Glue remover
Post by Scott B. »
Thank you all. I'll give them a shot.
Paul D.
Re: Glue remover
Post by Paul D. »
If those don't work or if you have some lying around, try denatured alcohol (methylated spirits). That worked for me taking off some tape residue that was 10 years old on the stern deck, but smooth and non skid.
Scott B.
Re: Glue remover
Post by Scott B. »
Thanx Paul. I have some and was planning to try that with the others. And u think it will not harm the glass?
Paul D.
Re: Glue remover
Post by Paul D. »
I cleaned up some tape residue from when we bought the boat and trucked it. I actually put the tape on to prevent something from flapping around. It was a plastic similar to shrink wrap tape. I took it off when fitting out the boat but a bunch of it stuck and I couldn't get it all off. After looking at the residue turn black for 10 years I finally got serious with some denatured alcohol on a rag and rubbed it off a few years ago. Deck gelcoat and original nonskid paint all seems fine.
Scott B.
Re: Glue remover
Post by Scott B. »
Thank u. It's on my list
Scott B.
Re: Glue remover
Post by Scott B. »
Bye. Is that the same as "mineral spirits"?
