Replacing typhoon lines
Looked up in the owners manual the line length for the jib, and genoa lines. 32' and 20'. My question is is that normally I would cut one line and fold it in half and fasten it to the jib leaving two lines 16' long and even shorter for the genoa. Or is each section that length? 10ft lines dose not look like it would work for the genoa. If anyone know the magic number for sheet length for them let me know thanks
Re: Replacing typhoon lines
For normal sheets, tied to the sail and run to winches, each side will be one boat length for a jib and one and a half for genoas. I'd expect to have two 20' jib sheets and two 32' ones for the genoa.
Looks like a good time to buy 104' of 3/8". Vintage Sta-Set has a wonderful feel and looks good on any CD. The slippery polyester lines end up as halyards or other more permanent lines like topping lifts...
http://www.sailrite.com/PDF/Rope%20Sele ... ations.pdf
You can leave the sheets full length (64 and 40'), and make an alpine loop in the middle.
http://www.animatedknots.com/alpinebutt ... crollPoint
Leave about a 6" loop, and then Cow Hitch it by passing the loop through the clew ring, then pass the tails through the loop and pull through. Move the knot near the sails and it will roll over the shrouds with less snagging. In a few years you cut the middle, reverse the ends, and use conventional knots.
Thanks helps a lot
for any of a number of reasons my genoa sheets seem to end up wet for some of the length, so for a full length of rope i find the mid point and tie in a snap shackle. that way when i douse the genoa, the sheet gets detached from the sail easily and gets hung to dry while the sail goes back in the bag - being a hanked on sail as it is.
- Markst95
3/8" will be nicer on the hands but 5/16" works well, especially with the smaller Ty Cleats.
Am I reading you correctly? Manual seems to say the inverse, i.e., Jib sheet 32' Genoa 20' ...?Maine_Buzzard wrote:For normal sheets, tied to the sail and run to winches, each side will be one boat length for a jib and one and a half for genoas. I'd expect to have two 20' jib sheets and two 32' ones for the genoa.
Skeep
You are...
I have my doubts about the manual. Can you link to it?
If the jib was on a club foot with a block to the deck, I could see the 32' single sheet.
But never 20' for genoa sheets.
For my genoas, the lazy sheet has to circle back forward around the shrouds and mast to the winch, and needs to be long.
Run dead down, hold it out with a whisker pole, the distance from the clew to the far shrouds and back to the winch will be 25' or so on a 'Phoon...
I use both ends of 65' spinnaker lines on Guppy, I'd never believe it would take that much but it does.
Hmmm, I see. On my Ty, have as written, and they function perfectly. I guess size of genoa also plays into this. But on Baggy Wrinkles I'm pretty much set up "stock" and the measurements were spot-on for me. I took the stock measurements from the back of the manual where it lists all the dories in sequence.
Skeep
I would be interested to learn your thoughts on a Lark's Head knot if using one continuous jib or Genoa sheet. I used a Lark's Head on my jib sheet(s) on my Ty Weekender.Maine_Buzzard wrote:You can leave the sheets full length (64 and 40'), and make an alpine loop in the middle. . . . Leave about a 6" loop, and then Cow Hitch it by passing the loop through the clew ring, then pass the tails through the loop and pull through. Move the knot near the sails and it will roll over the shrouds with less snagging. In a few years you cut the middle, reverse the ends, and use conventional knots.
The Lark's Head is described as prone to slipping if only one side is loaded. That said, I've never had a problem with my Genoa sheet(s) attached that way.Sea Hunt Video wrote:I would be interested to learn your thoughts on a Lark's Head knot if using one continuous jib or Genoa sheet. I used a Lark's Head on my jib sheet(s) on my Ty Weekender.
Lark's head and cowhitches seem to be different names for the same knot. If it works, go for it.
James
James:Maine_Buzzard wrote:Lark's head and cowhitches seem to be different names for the same knot. If it works, go for it.
My apologies. As usual I was not clear. I agree the Lark's head and cow hitch knots are the same. What I am trying to understand is the advantage of adding the Alpine loop.
Thanks.
Is there something about my answer that you didn't like?Sea Hunt Video wrote:What I am trying to understand is the advantage of adding the Alpine loop.
![Sad :(](./images/smilies/icon_sad.gif)
Oh! It lets you use the cow hitch without having it slip. I swap it from genoa to yankee without thinking too much.
The alpine loop snags less than bowlines when tacking and is fast to tie correctly.
Not cranky- but I can feel skeep's finger poking in my ribs...
Neil:Neil Gordon wrote:Is there something about my answer that you didn't like?Sea Hunt Video wrote:What I am trying to understand is the advantage of adding the Alpine loop.
No, I appreciate your answer. I had not read about slippage. Thanks.
My interest was in understanding Jim's use of the Alpine loop and then adding the Lark's head (cow hitch) knot. Neil, please try to remember I ain't the sharpest tool in the tool chest.
