Does anyone have an opinion on closed vs. open chocks?
Chocks
Re: Chocks
If my bow pennants did not run through the gated stainless + bronze chocks that came with the boat, I might consider the closed model you show, because I would not want the pennant jumping out of the chocks and chafing.
That said, for the stern, I deal with the open chocks for my dinghy painter, even through the line jumps out from time to time when underway.
S/V RESOLVED. 1983 CD-27. Westerbeke W-13.
- tjr818
Re: Chocks
It depends on whether or not you lock your prop, or tiller vs. wheel.
In my limited experience, I prefer the open chock as it is easier to use.
Perhaps in a boisterous anchorage the closed chocks would be better, but we have been lucky enough to avoid that situation - so far.
Re: Chocks
The best of both worlds.
Re: Chocks
Another option. Unlikely a line would come out of this chock accidentally (given the horizontal force) but still easy to remove intentionally.
